Amphetamine Radio
Amphetamine Radio often transmits several SSTV images throughout their broadcasts and appears to be one of the most prolific transmitters of SSTV, along with other frequent users of SSTV including Wolverine Radio and Pee Wee. Some of their broadcasts consist entirely of SSTV images. SSTV is usually transmitted in Scottie 1 mode. In addition to voice IDs, MCW (modulated CW) IDs are usually transmitted, often either before or after SSTV frames are sent. Amphetamine Radio's SSTV content often consists of vintage "pin-up" style erotica, women in fishnet stockings, and other assorted SSTV images. Amphetamine Radio has also transmitted "SSTV requests" made by listeners. Amphetamine Radio often adds the tagline "Pin-Up Pirate Radio" or "High Speed Pirate Radio" to their identification and has claimed to be "the most tweaked out station on the 43 meter band".
Amphetamine Radio has not been heard for quite some time (as of December 2023). The op has indicated that he is currently unable to put up a proper antenna and will attempt to resume broadcasts once that situation changes.
