Amphetamine Radio
Revision as of 19:51, 12 September 2025 by R4002 (Talk | contribs)
is a pirate radio station that first appeared in the summer of 2015.  It is normally heard on 6925 USB but has been heard on "offset" frequencies 6923 and 6924.7 in addition to 6930, 6950 and 6955 kHz. Amphetamine Radio has also experimented with lower frequencies, including 3375 kHz and several others in the 4 MHz band.
Amphetamine Radio has not been heard for quite some time (as of September 2025). The op has indicated that he is currently unable to put up a proper antenna and will attempt to resume broadcasts once that situation changes.
