Letter beacon
Revision as of 09:18, 25 February 2010 by Strange Attractor (Talk | contribs)
  • Cluster beacons
Location of letter beacons
The leter beacon radio transmissions were discovered in the late 1960s. Their presence became known to the wider amateur radio community in 1978, when beacon “W” started transmitting on 3584 kHz, in the 80 meters band. There is indirect evidence that this particular transmitter was located in Cuba. (3)
In 1982 there were also reports, supposedly based on HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at 48° 30' N - 134° 58' E, near the city of Khabarovsk in the USSR. (4), (5) A few years later, it was suggested that the "K" beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the "U" beacons were located at the Barents Sea coast, between Murmansk and Amderma. (6)
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (inactive)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
The single letter beacons can be classified in two groups, the "Cluster beacons" and the "Channel markers". A beacon "P" exists in both groups. A third group, the FSK beacons, is now extinct. The following sections list the beacons currently (December 2007) active, according to published listeners’ reports.
Cluster beacons
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", "A", "M" and "K") have been regularly reported near 3594, 4558, 5154, 7039, 8495, 10872, 13528, 16332 and 20048 kHz. The term "cluster beacons" is frequently used for them, as these beacons transmit in parallel on frequencies only 0.1 kHz apart. These beacons transmit only their single-letter identifier in standard CW (A1A) using morse code.
ID letter Frequencies (kHz)
D 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7
P 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8
S 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9
C 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0
A 3595.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 (10)
F 7039.2
K 5154.3, 7039.3, 8495.3
M 5154.4, 7039.4, 8495.4, 10872.4, 13528.4, 16332.4
R 4325.9, 5465.9
V 3658.0, 5141, 5342, 6430.7, 6809, 7027.5, 8103.5, 10202
P (12) 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079
C 8000
FSK beacons
This group includes the "K" and "U" beacons, which are no longer active. They transmitted their morse code single letter identification by shifting the frequency of the carrier by approximately 1000 Hz. This mode of "FSK-CW" is designated F1A. The use of FSK indicated that the transmitter was suitable for FSK data transmissions, like Radioteletype.
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
According to ENIGMA the cluster beacons are used by the Russian Navy (and especially the submarine branch) to find the most suitable radio frequency for contact based on current radio propagation conditions. (7)
Similar systems
A few aero navigation Non Directional Beacons also transmit single letter identification codes. They can be easily distinguished from Letter beacons as they transmit in the allocated low frequency and medium frequency bands, most of them are listed in appropriate aviation handbooks and their transmission mode is A2A (full carrier with audio modulation).
Notes & References
  15. Poundstone Willian: Big Secrets, Quill, New York, 1983, ISBN 0688048307, pages 191-193
  4. Spooks mailing list.
An article from Wikipedia [2], published under Creative Commons CC-BY-SA-3.0 free license.
