Ionosonde
Revision as of 15:01, 5 September 2010 by Strange Attractor (Talk | contribs)
Works.png This article or section is under construction.
An IRX-58-23 ionosonde system.
A ionosonde, or chirpsounder, is a special radar for the examination of the ionosphere.
Description
An ionosonde consists of:
  • A high frequency (HF) transmitter, automatically tunable over a wide range. Typically the frequency coverage is 0.5–23 MHz or 1–40 MHz, though normally sweeps are confined to approximately 1.6–12 MHz.
  • A tracking HF receiver which can automatically track the frequency of the transmitter.
  • An antenna with a suitable radiation pattern, which transmits well vertically upwards and is efficient over the whole frequency range used.
  • Digital control and data analysis circuits.
The transmitter sweeps all or part of the HF frequency range, transmitting short pulses. These pulses are reflected at various layers of the ionosphere, at heights of 100–400 km, and their echos are received by the receiver and analyzed by the control system. The result is displayed in the form of an ionogram.
The basic ionosonde technology was invented in 1925 by Gregory Breit and Merle A. Tuve <ref name="Judd1988">Template:Cite book</ref> and further developed in the late 1920s by a number of prominent physicists, including Edward Victor Appleton. The term ionosphere and hence, the etymology of its derivatives, was proposed by Robert Watson-Watt.
An ionosonde is used for finding the optimum operation frequencies for broadcasts or two-way communications in the high frequency range.
Typical ionogram
Template:Reflist
