Ionosonde
Description
An ionosonde consists of:
Ionogram
The maximum usable frequency (MUF) for radio waves transmitted at a low angle over the horizon is approximate 3 times the highest frequency returned to the ionosonde from radio waves transmitted directly upwards (to the zenith of the location). Therefore, in the example above, where fxI was measured as 6.2 MHz, the MUF for ionospheric reflection at the area of the ionosonde was calculated as 18.7 MHz.
- [The UK Ionospheric Monitoring Group
