High Frequency Beacon
Revision as of 08:27, 19 September 2010 by Strange Attractor (Talk | contribs)
High Frequency Beacon is a colloquial term for an unlicensed radio beacon that does not follow government regulations for operation (such as Part 15), and is technically illegal.
Freq (kHz) Station ID Location Operation Notes
3450 OK OK
4077.27 MO Oklahoma Solar 200 mW 118ft end fed wire 24/7
4094.8 Dasher Sputnick - 60 dash/min, night only Location: West Virginia Reported off air September 2009 due to lack of QSLs
4096 ......_ 6 dots 1 dash
4102.3 W... The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the s.e. California desert, it sends lots of dits; and no wind, no dits.
4194 MX Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID.
4608 MXC Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX.
5484 SD San Diego, CA
5499.13 WA Dasher
6815 SV1TEST presumably in Greece no further info. (Source: UDXF)
6852 PRV Preveza, Greece 15 W Op: SW2HMU & SV1BJW (Source: UDXF) [1]
8001.5 S S.W. Arizona sun-only, 1 watt. strong signal daytimes
8188.7 W Colorado Solar/battery 100 mW dipole daylight /7 Location: Colorado
8211.7 OR
10236.7 FL Dasher
14400.3 UFO Colorado
External Links
