High Frequency Beacon
Description
| Freq (kHz) | Station ID | Location | Operation Notes |
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 (back on the air, recently reported on 6 April 2009) |
| 3450 | OK | OK | (Youtube video) |
| 4062 | C | SW, probably CA | Very drifty, but slow drift, logged form 4052 to 4063. Its morse is not timed correcctly, it is probably sending a C with a short first dah (longer than dit, shorter than dah), but it could be an ER with a long dit, or a TR with a short dah. 24/7 |
| 4078.14 | WW | Colorado | 300-400 mW Inverted L night time only |
| 4077.27 | MO | Oklahoma | Solar 200 mW 118ft end fed wire 24/7 (Youtube video) |
| 4079 | TMPnnn | SW Arizona | The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt |
| 4089 | . | Death Valley N.P. | About 80 dits/minute, 24/7, 500 mW to inv. vee. dipole |
| 4094.2 | PA | Arkansas | Solar power 200 mW Dipole 24/7 |
| | WV | | |
| 4096 | ......_ | VA | 6 dots 1 dash |
| 4096.1 | Dasher | Joshua Tree N.P. | 4.5 sec long dashes (about 13 dashes per min.) - big signal - north-facing dipole ('Coxie') 24/7 |
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') |
| 4097.2 | Dasher | Inyo County, CA near DVNP | 55 dashes per minute with chirp when sun is low; day-only, at 5300 ft. elevation ('Inyo-whooper'), inv. vee., 0.5w |
| 4102.3 | W... | s.e. California desert | The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the , it sends lots of dits; and no wind, no dits. |
| 4194 | MX | Europe | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. |
| 4608 | MXC | Europe | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX. |
| 5157.6 | Dasher | Florida | BLINKY 200 mW Dipole 24/7 |
| 5499.13 | WA | Dasher | |
| 5678.4 | Dasher | Colorado | PIKE solar/battery 100 mW Dipole 24/7 "Honker" |
| 6549.3 | FL | Florida | 300 mW Dipole 24/7 |
| 6626.2 | S | Inyo County, CA, near DVNP | About 60-200 dashes per min., sun-only, ~200 mW ('Rocky') |
| 6626.4 | Dits | Mojave N.P. | Fast 'drippy' sounding dits about 100/min., sun-only, 1.5 watts ('Rainy') |
| 6700.4 | Dasher | Joshua N.P. | About 62 dashes per min., 24/7 (Hexy2k) |
| 6815 | SV1TEST | presumably in Greece | no further info. (Source: UDXF) |
| 6852 | PRV | Preveza, Greece | 15 W Op: SW2HMU (Source: UDXF) [1]. Defunct? |
| 6994.8 | - | Norfolk, UK | "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS RRR RRR RRR REPORTS TO UKBEACON _ GMAIL.COM" (Source: UDXF) |
| 8001.5 | S | S.W. Arizona | sun-only, 1 watt. strong signal daytimes |
| 8003 | Dasher | Colorado | Solar/battery dipole 24/7 "Pike 78" 78 dashes/min |
| 8188.7 | W | Colorado | Solar/battery 100 mW dipole daylight /7 Location: Colorado |
| 8211.7 | OR | ||
| 8261 | F | Western Canada | 250mW into a 1/2 wave inverted vee, 1400-0500 |
| 8350 | Dasher | North Carolina | |
| 10236.7 | FL | Dasher | |
| 11002.7 | CO | Colorado | Solar battery 300 mW dipole 24/7 |
| 14400.3 | UFO | Colorado | |
- HiFER
External Links
