High Frequency Beacon
Description
| Freq (kHz) | Station ID | Location | Operation Notes | |
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 (back on the air, recently reported on 6 April 2009) | |
| | WV | | ||
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') | |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') | |
| 5499.13 | Dasher | WA | ||
| 6815 | SV1TEST | Athens, Greece (KM18VB) | Active, no further info. (Source: UDXF) (Youtube video) | |
| 6852 | PRV | Preveza, Greece | 15 W Op: SW2HMU (Source: UDXF) [1]. Defunct? | |
| 6994.8 | - | Norfolk, UK | "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS RRR RRR RRR REPORTS TO UKBEACON _ GMAIL.COM" (Source: UDXF) | |
| 8001.5 | S | S.W. Arizona | sun-only, 1 watt. strong signal daytimes. Recently reported on 8000.6 kHz (Source: UDXF). | |
| 8188.7 | W | Colorado | Solar/battery 100 mW dipole daylight /7 Location: Colorado | |
| 8211.7 | OR | |||
| 10236.7 | FL | Dasher | ||
| 14400.3 | UFO | Colorado | ||
- HiFER
External Links
