High Frequency Beacon
Revision as of 17:22, 19 July 2011 by Strange Attractor (Talk | contribs)
Description
PRV (6852 kHz) under test
2097 A Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 April 6, 2009
3450 OK OK (Youtube video)
3810 SV1TEST Athens, Greece
(KM18VB)
4096 ......_ VA 6 dots 1 dash
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') July 2011
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') July 2011
4097.2 Dasher Inyo County, CA
near DVNP
5484 SD San Diego, CA
5499.13 Dasher WA
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST Athens, Greece
(KM18VB)
X9Q S.E. Europe or
Middle East
No further info. (Source: UDXF) June 2011
FU N. America Active June 2011, no further info. (Source: A*C*E [1]) (MP3 audio recording) July 19, 2011
6816 HA N. America Active July 2011, no further info. (Source: A*C*E [2], HF Underground Forum [3]) .
July 9, 2011
6852 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. Former website [4] closed. 2011
6994.8 - Norfolk, UK
(JO02)
2011
8211.7 OR
8350 Dasher North Carolina
10236.7 Dasher FL
  3. "PRV" was often reported during the past few months and was unid until Linkz submitted a link to websites about this station. Linkz writes: I have no idea if this station is legit or a pirate. It's operator is Eystathios Karastathis (SW6HMU) from Preveza, Greece. He writes on his blog "PRV - 6852 kHz 15w cw BEACON with Dipole Ant on the air 17.30 pm- 8.00 am". According to his blog there is also a MF beacon "PRV beacon 500-531 khz am/cw 400 Watt" and a local AM broadcasting station "Studio 421" on 1655 kHz”. This beacon was last reported to UDXF on April 18, 2011.
External Links
