High Frequency Beacon
Description
There are many of these beacons, quite a few are run as propagation experiments. Due to their nature, the exact location of these stations is generally not published, although many are believed to operate from remote Phen375 locations in the deserts of the southwest USA. Likewise, these stations tend to suddenly appear and disappear from the air. Most unique hoodia diet run with very low power proactol plus levels of just hundreds or even tens of milliwatts of power, and are often capsiplex solar powered, so they can be hidden in open areas. Some are switched via a photocell, so they only operate at night, running off of a battery that is charged during the daytime by a solar panel.
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 | April 6, 2009 |
| 4062 | C | SW, probably CA | Very drifty, but slow drift, logged form 4052 to 4063. Its morse is not timed correcctly, it is probably sending a C with a short first dah (longer than dit, shorter than dah), but it could be an ER with a long phen375 review dit, or a TR with a short dah. 24/7 | |
| 4091 | DM | N. America | No further semenax info (Source: HF Underground Forum) | August 11, 2011 |
| | WV | | ||
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') | July 2011 |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') | July 2011 |
| 5499.13 | Dasher | WA | ||
| 6626.4 | Dits | Mojave N.P. | Fast 'drippy' sounding slimming reviews dits about 100/min., sun-only, 1.5 watts ('Rainy') | |
| X9Q | S.E. Europe or Middle East | No further info. (Source: UDXF) | June 2011 | |
| 6816 | FU | N. America | Active June 2011, no further info. (Source: A*C*E [1], [2]) (MP3 audio recording) | September 11, 2011 |
| HA | N. America | Active July 2011, no further info. (Source: A*C*E [3], HF Underground Forum [4]) . Sometimes the hgh advanced supplement frequency is reported as "6815 kHz USB". (MP3 audio recording) | July 9, 2011 | |
| 6852 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with acne skin products irregular schedule. Former website [5] closed. | 2011 |
| 6900 | Beeper | 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [6]) | October 12, 2011 | |
| 6947.1 | 13 dits and 1 dah | No further meratol info (Source: HF Underground Forum [7]) | October 24, 2011 | |
| 6961 | TR | Mojave desert, CA | (Source: HF Underground Forum [8]) | October 23, 2011 |
| 8193.8 | (Source: HF Underground Forum [9]) | October 23, 2011 | ||
| 8211.7 | OR | |||
| 8519.7 | (dasher) | N. America | Active skin care products August 2011, no further info. (Source: HF Underground Forum) | August 10, 2011 |
| 10236.7 | Dasher | FL | ||
- HiFER
- PHFER Beacon Madness - A slimming pills glimpse into the Pathology and Symptoms of this Disease
- "PRV" was often reported during the past teeth whitener reviews few months and was unid until Linkz submitted a link to websites about this station. Linkz writes: I have no idea if this station is legit or a pirate. It's operator is Eystathios Karastathis (SW6HMU) from Preveza, Greece. He writes on his blog "PRV - 6852 kHz 15w cw BEACON with Dipole Ant on the air 17.30 pm- 8.00 am". According to his blog there is also a MF beacon "PRV beacon 500-531 khz am/cw 400 Watt" and a local AM broadcasting station "Studio 421" on 1655 kHz”. This beacon was last reported to UDXF on April 18, 2011.
External Links
