High Frequency Beacon
Revision as of 04:46, 4 March 2012 by Strange Attractor (Talk | contribs)
Description
PRV (6852 kHz) under test
2097 A Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 [1] January 24, 2012
3450 OK OK (Source: HF Underground Forum [2]) (Youtube video) January 5, 2012
3810 SV1TEST Athens, Greece
(KM18VB)
4079.7 TMPnnn SW Arizona The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [3] February 27, 2012
4096 ......_ VA 6 dots 1 dash
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [4] February 2012
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [5] February 2012
4097.2 Dasher Inyo County, CA
near DVNP
5484 SD San Diego, CA
5499.13 Dasher WA
6547.0 PRV Preveza, Greece Op: SW6HMU, QSL via [email protected] (Source: UDXF). Also reported on 6852.1 January 22, 2012
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST Athens, Greece
(KM18VB)
X9Q S.E. Europe or
Middle East
No further info. (Source: UDXF) June 2011
6816 FU N. America Active June 2011, no further info. (Source: A*C*E [6], [7]) (MP3 audio recording) January 20, 2012
HA N. America Active July 2011, no further info. (Source: A*C*E [8], HF Underground Forum [9]) .
July 9, 2011
6852.1 PRV Preveza, Greece 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via [email protected] Former website [10] closed. Reported also on 6547.0 kHz December 31, 2011
6900 Beeper 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [11]) October 12, 2011
6947.1 13 dits and 1 dah No further info (Source: HF Underground Forum [12]) October 24, 2011
6961 TR Mojave desert, CA (Source: HF Underground Forum [13]) October 23, 2011
6994.8 - Norfolk, UK
(JO02)
2011
7542 55555 W Europe or NE USA (Source: [14], N&O-173(5), UDXF) March 1, 2012
8193.8 (Source: HF Underground Forum [15]) October 23, 2011
8211.7 OR
8350 Dasher North Carolina (Source: HF Underground Forum [16]) December 31, 2011
10236.7 Dasher FL
11428 CZ  ? (Source: HF Underground Forum [17]) January 3, 2012
External Links
