MURS
Multi Use Radio Service
Simplex:
| Freq MHz | ||
| 151.820 | ||
| 151.880 | ||
| 151.940 | ||
| 154.570 | ||
| 154.600 |
Voice and data service for use by the general public. Personal, hobby and business uses permitted. All users must share frequencies. Repeaters and store-and-forward packet is prohibited. Per FCC rules, grandfathered users may operate higher power and/or repeater systems on these frequencies under the terms of their previous licenses.
Although FCC rules prohibit high power and repeater operations on the MURS frequencies, reports on various radio forums and by scanner listeners have indicated that hobbyists in certain areas are simplex repeaters, high power base stations, high power mobiles, and cross-band repeaters (often cross-band connected to GMRS or FRS frequencies) on the MURS frequencies. Just like hunters on VHF marine], the effective lack of FCC enforcement makes setting up and operating these systems quite attractive.
MURS has been adopted by many big box retailer stores such as Wal-Mart, Sam's Club, etc. Wal-Mart often uses these frequencies without CTCSS or DCS making interference a common issue.
MURS is unique among the American (FCC Part 95) personal radio services (CB, FRS, GMRS, etc) in that AM, FM, and CW modes are allowed. F2D modulation and A2D modulation (digital using FM or digital using AM) are also permitted on the MURS frequencies. Voice inversion scrambling is permitted and offered as an option on radios such as the Motorola RMM2050 MURS portable radio. CTCSS and DCS are often used to facilitate frequency sharing.
Maximum bandwidth on 151.82 MHz, 151.88 MHz and 151.94 MHz is 11.25 kHz and maximum bandwidth on 154.57 MHz and 154.6 MHz is 20 kHz.
