11 meter
| 26.950 MHz to 26.960 MHz | 26950 kHz to 26960 kHz | Internationally allocated fixed (center frequency: 26.955 MHz 26955 kHz, often used for data links) |
11 meter is often used by freebanders or CB operators using the "freeband" frequencies from between 25 MHz and CB channel 1 (26.965 MHz) and CB channel 40 (27.405 MHz) and the bottom edge of the 10 meter amateur band (28.000 MHz). Common freeband frequencies include:
- 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
