VHF low band VHF-low
VHF high band VHF band
UHF band
800 MHz band
Allocated by NTIA, not the FCC. VHF frequencies in the 162-174 MHz VHF high federal government band, UHF frequencies in the 406-420 MHz UHF federal government band. See also: SINCGARS and VHF aircraft band, the UHF military aircraft band (225-400 MHz or 225-380 MHz) as well as the 380-400 MHz UHF band and 137-144 MHz / 148-150.7625 MHz VHF bands.
UHF band
Oil Spill Cleanup
These frequencies are part of the Business/Industrial Radio Pool (Business Radio Service) under Part 90 of the FCC rules. They are specifically designated for inter-system and intra-system communications relating to oil spill cleanup response and recovery operations. Use of CTCSS tones 156.7 Hz and 167.9 Hz appear to be "standardized" in some areas, but various tones are used. Digital voice modes such as Project 25 and DMR are also used, especially on the VHF/UHF frequencies. These frequencies are often used in conjunction with other business radio frequencies and the interop frequencies listed elsewhere in this article.
- 36.2500 MHz - Oil spill cleanup/interop (simplex or repeater input/output, paired with 36.25 MHz)
- 41.7100 MHz - Oil spill cleanup/interop (simplex or repeater input/output, paired with 41.71 MHz)
- 150.9800 MHz - Oil spill cleanup interop (simplex or repeater input/output, often paired with 158.445 MHz)
- 154.5850 MHz - Oil spill cleanup interop (simplex or repeater input/output, often paired with 159.480 MHz)
- 454.0000 MHz - Oil spill cleanup interop (simplex or repeater output, paired with 459.0 MHz)
- 459.0000 MHz - Oil spill cleanup interop (simplex or repeater input, paired with 454.0 MHz)
