Pirate shortwave broadcasts tend to be on well-known frequencies (or at least relatively small bands that can be quickly scanned with a traditional radio/receiver or watched/recorded with a SDR). This allows listeners to quickly find a pirate station when it comes on the air, as they only have a relatively few number of fixed places to look. Many pirate radio listeners park receivers on 6925 kHz. Some of the locations on the HF band that are in frequent use include:
Contents[hide] |
Last updated: May 2019
1610-1700 kHz | AM - Mediumwave pirates (see also 1710 kHz and 1720 kHz) |
1710 kHz | AM - Mediumwave pirates |
1720 kHz | AM - Mediumwave pirates - known as the "AM pirate clear channel" |
3375 kHz | AM/USB - used by Amphetamine Radio |
3390 kHz | AM/USB - used by Old Time Radio in February 2019 and March 2019 |
3425 kHz | AM - used by The Crystal Ship (also reported on 3430) |
3440 kHz | AM/USB - reported use in 2018 |
3465 kHz | AM - reported use in 2017 |
4015 kHz | AM/USB - used by Amphetamine Radio and others |
4020 kHz | AM/USB |
4025 kHz | AM/USB |
4060 kHz | AM/USB |
4065 kHz | AM/USB |
4080 kHz | AM/USB |
4085 kHz | AM/USB - used by X-FM in late 2018 |
4140 kHz | AM/USB - used by Mix Radio International |
4145 kHz | AM/USB - used by Mix Radio International |
5010 kHz | AM - used by Relay Station |
5015 kHz | AM - used by Relay Station |
5150 kHz | AM - used by Relay Station |
5200 kHz | AM - used by Relay Station |
6150 kHz | AM - used by European Pirates |
6220 kHz | Used by Mystery Radio in Europe and other European Pirates (see 49 meters below) |
6750 kHz | AM/SSB - reported in use August 2017 |
6770 kHz | AM - used by Old Time Radio or OTR, considered to be OTR's "home channel" |
6780 kHz | AM/USB - including nearby frequencies 6777 kHz, 6777.7 kHz, 6778 kHz and 6779 kHz |
6790 kHz | AM/USB - including nearby frequency 6789 kHz |
6805 kHz | AM/SSB (repored use by UNID Europirates) |
6815 kHz | AM (repored use by UNID Europirates) |
6840 kHz | AM |
6850 kHz | usually AM |
6855 kHz | usually AM |
6868 kHz | AM/USB - noted use by Mix Radio International (May 2019) |
6870 kHz | AM/USB |
6875 kHz | usually AM - noted use by The Crystal Ship (often 6876 kHz or similar close frequencies) |
6880 kHz | usually AM - used by Relay Station (noted use in late 2018) |
6885 kHz | AM/USB |
6886 kHz | AM/USB - used by Mix Radio International in October 2018 |
6888 kHz | usually AM - noted use by Unknown Name Radio Network |
6890 kHz | AM/USB |
6900 kHz | usually AM, although 6900 LSB and 6900 USB are both heavily used by Spanish-speaking "peskies" |
6905 kHz | AM - noted use by Unknown Name Radio Network, another commonly use pescadore frequency in LSB mode |
6910 kHz | AM/USB - Used by Seven Trees Radio and Clever Name Radio |
6915 kHz | AM/USB |
6920 kHz | AM/USB |
6923 kHz | AM/USB - used by Amphetamine Radio, Fess Parker Radio, Yeah Man Radio and others |
6925 kHz | most common frequency - virtually all modes have been heard +/- 1-2 kHz |
6927 kHz | AM - noted use by Yeti Radio in 2018 |
6930 kHz | AM/USB |
6935 kHz | AM/USB - Latin American pirates can also be heard here (i.e. AD149 on 6934.8 kHz or 6934.9 kHz AM) |
6940 kHz | AM/USB - noted use by Clever Name Radio |
6945 kHz | AM/USB |
6950 kHz | AM/USB |
6955 kHz | AM/USB |
6960 kHz | AM/USB - noted use by Radio Illuminati |
6965 kHz | AM/USB |
6969 kHz | LSB/USB - Used by Cold Country Canada and others |
6970 kHz | AM |
6973 kHz | AM - Latin American pirates can also be heard here, specifically Lupo Radio |
6975 kHz | AM/USB - often used by X-FM (also heard on 6970) |
6985 kHz | AM - Latin American pirates |
6995 kHz | AM/SSB - recently (July 2017) used by KUNT |
7415 kHz | historically, an extremely active frequency, more recently occupied by WBCQ |
7425 kHz | historically, an extremely active frequency prior to the movement down to 43 meters |
7465 kHz | AM - noted use by YHWH religious pirate (September 2018) |
7470 kHz | AM - noted use by YHWH religious pirate |
7480 kHz | AM - noted use by YHWH religious pirate (May 2019) |
15070 kHz | active in the early 1990's by Europirates and pirates in North America, but recently quiet due to the solar cycle low |
Euro-Pirate Radio Frequencies
- 3920-3950 (75 meters)
- 9500-10200 kHz
- 7400-8100 kHz
- 6765-7000 kHz
- 5000-6300 kHz
- 8000 kHz - Radio Casa
- 6925.1 kHz - RCW Chile
- 6250 - Used in the 1980s
