SINCGARS
Single channel mode, also known as fixed frequency, is referred to as VULOS, or VHF UHF Line Of Sight. It is a catch-all term for VHF-FM 30-88 MHz, VHF-AM 108-150 MHz, VHF-FM 136-174 MHz, UHF-AM 225-399.975 MHz and UHF-FM 400-512 MHz fixed frequency clear (plaintext, or PT) or encrypted (ciphertext, or CT) simplex communications nets. Duplex or half-duplex repeaters (relay, retrans) or retransmission facilities may be used for VULOS nets. Frequencies in the 30.000 to 87.975 MHz range may be used for these nets in conjunction with SINCGARS, UHF SATCOM and UHF aircraft HAVE QUICK nets. PRC-148, PRC-152 and similar radios make reference to the VULOS radio net type. See also: PRC-150 HF/VHF radio (1.5-30 MHz SSB and various digital modes, 30-60 MHz [59.999 MHz] FM only. FM radios often have a "deviation" (bandwidth) setting. SINCGARS and fixed channel mode is generally set to 8 kHz deviation (36 kHz bandwidth) at 25 kHz steps. Land mobile settings include 5 kHz deviation (20 kHz bandwidth) and 2.5 kHz deviation (10 kHz bandwidth, regular narrow FM).
Most radios include repeater capability (called RETRANS or retransmit in military usage). Compatible with previous-generation FM radios such as the PRC-25, PRC-77, PRC-1077, HH7700 and dozens of other similar tactical handheld, manpack and vehicle-mounted radios operating in the 30-76 MHz (30.00 to 75.95 MHz in the original PRC-25/PRC-77 and VRC-12 channeling) or 30-88 MHz range. NATO military forces and many other military forces use similar frequencies for tactical purposes, almost always with FM voice. The US military fields radios that operate in the 30-174 MHz and 30-512 MHz ranges to support SINCGARS, regular VHF-FM, 136-174 MHz VHF-high band services like VHF marine, aircraft radios, SATCOM and interoperability with other radio systems that use VHF/UHF.
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
It should be noted that military operations in single channel mode are found on any frequency between 30.000 and 87.975 MHz outside the government/military exclusive use bands on a non-interference basis. Use of the 150.0 Hz CTCSS or PL tone squelch allows for frequency sharing with other users. This, combined with the fact that civilian allocations in the 30-50 MHz band use 20 kHz channel steps, compared to the 25 kHz channeling used by military VHF-FM or SINCGARS systems. The 150 Hz tone squelch is close enough to the civilian 151.4 Hz CTCSS tone that many scanners or communications receivers will decode military VHF FM traffic as having 151.4 Hz CTCSS when in reality they are transmitting 150 Hz. Use of 150 Hz also permits the operation of "relay" (repeater) setups using two radios, the appropriate cables and filters and a high elevation location. Relay functionality has been included in FM tactical radios since the SCR-300 (BC-1000) series. It was not, however, heavily used until the Vietnam war. Most single channel battlefield relay sites use RC-292 (20-70 MHz) or similar high performance antennas. FH retrans sites use the more modern OE-294 broadband antenna system. The wide frequency range of modern FM radios allows for maximum flexibility in choosing frequency pairs.
Background and History
| 60.000 MHz to 80.000 MHz | TBS Series "Talk Between Ships" - Ship-to-Ship voice radio 60-80 MC radio - US Navy | Crystal controlled 20 kHz steps - TBS crystals for 65.74 MHz and 72.50 MHz have been found |
| 27.000 MHz to 38.900 MHz | American Artillery Band (U.S. Army) | 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628 |
| 38.000 MHz to 54.900 MHz | American Infantry Band (U.S. Army) | 100 kHz (channels 380-549), PRC-10, PRC-10A |
| 40.000 MHz to 48.000 MHz | American Infantry Band - portable tactical radios - WWII vintage | 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio |
| 3500 kHz to 6000 kHz | SCR-536 Handheld Radio 3.5 MHz to 6.0 MHz the "walkie-talkie" - actually called a Handie-Talkie or HT | Crystal controlled, 360mw AM voice only - short range tactical communications HF AM |
| 3800 kHz to 6500 kHz | SCR-694 3.8 MHz to 6.5 MHz AM, CW or MCW - portable or vehicle-mounted tactical AM voice, tone or straight CW | Crystal controlled, 10-20 mile range (voice, R/T), 20-40 miles range (tone, W/T) depending on antenna used |
| 3800 kHz to 5800 kHz | SCR-284 3.8 MHz to 5.8 MHz AM, CW or MCW - transportable or vehicle-mounted tactical AM voice, tone or straight CW | 24 watts transmit power (CW mode, W/T), 17 watts transmit power voice (W/T, AM voice) |
| 2000 kHz to 8000 kHz | Wireless Set No. 19 - British tank radio 2-8 MHz with very low power VHF "B" set built in, 229-241 MHz | Tank to tank command usage (A set - 2-8 MHz) and very short range tank communications (B set) |
| 47.000 MHz to 55.400 MHz | American Infantry Band - portable tactical radios - Korea War vintage - PRC-6 | AN/PRC-6 "banana radio" walkie talkie portable single-channel crystal controlled FM radio, 250mw output, 47-55.4 MHz FM |
| 27.200 MHz to 33.300 MHz | German Armor Tank Radio Panzer Radio Band - sometimes listed as 27.0 MHz - 33.4 MHz or 27.2 MHz - 33.4 MHz | 50 kHz channels - AM voice - this was, by far, the most common tank command/tactical radio band used |
| 42.000 MHz to 48.300 MHz | German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) | 50 kHz channels - AM voice, close air support and tank command nets |
| 28.000 MHz to 33.000 MHz | German Infantry Band (portable radios) | 100 kHz channels, actual coverage 27.8 MHz to 33.2 MHz |
| 32.000 MHz to 38.000 MHz | German Infantry Band (portable radios) | 100 kHz channels - Feldfu d and KL.Fuspr.d manpack portable infantry radios |
| 33.800 MHz to 38.000 MHz | German Infantry Band (transportable portable radios - higher power command sets) | 100 kHz channels |
| 30.000 MHz to 75.950 MHz | Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control | 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 and dozens of others |
| 30 MHz to 512 MHz | Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps |
| 2400-2500 MHz (2.4 GHz) | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams |
- 34.100 MHz - 41.700 MHz Ra120 Swedish manpack portable VHF FM tactical radio, 100 kHz steps
