Revision as of 18:02, 30 June 2020 by Commsigma (Talk | contribs)
Links associated with frequencies (such as 5000 kHz) will take you to an online receiver that is tuned so you have a chance to hear it live. Be sure to visit KiwiSDR Operating Information to learn more about how to operate these online receivers. There is a list and map or receivers available to use worldwide. Using an online receiver allows you to try out HF monitoring before investing in your own equipment. They are also helpful if you have limited capabilities to erect a large antenna or if your location has a lot of radio frequency interference.
What Can I Hear?
There is such a wide variety of things to listen to on HF it would be impossible to cover them all here. To get a taste for what is available here are some examples starting with the easiest to monitor. Please be aware that patience is one of your most important tools. Often times station only broadcast on a limited basis and are not on the air continuously. There are many factors that can help and impede your chances of reception so if you are not successful on your first attempt, keep trying!
Easy to hear
WWV WWVH(US) - 2500 kHz, 5000 kHz, 10000 kHz, 15000 kHz, 20000 kHz (WWV only), 25000 kHz (WWV only)
Shortwave Broadcasters
Amateur (Ham) Radio
Amateur radio operators are people who are licensed to use parts of the HF radio spectrum. Their operation and interest span from technical to having conversations with distant stations. There are many amateur radio bands on HF. Operators also operate many different modes - voice (AM, LSB, USB), digital, Morse Code, etc. Many of these modes can be monitored on online receivers without any special equipment. Some modes require special decoding hardware or software. The easiest to listen to would be voice communications. Here are a couple of examples of frequencies that have regular activity or nets. Again, propagation can affect whether or not stations can be heard or not.
75 meter - 3875 kHz, 3885 kHz (AM voice activity)
40 meter - 7253 kHz, 7255 kHz (LSB nets)
20 meters - Slow Scan TV (SSTV) - 14230 kHz (with SSTV decoder on)
Moderately easy to hear
More difficult to hear
Rare, exotic stations are hunted by groups of listeners called DXers. Often they listen for days, weeks, months, or years in the hope of receiving a specific station. A combination of patience, luck, equipment, and propagation can determine whether the elusive station will be heard. These stations can be low power stations that are target a local audience, political clandestine stations that are short lived and operating illegally in their country, or stations that have a very restricted on the air schedule. Sometimes propagation cooperates and allows easier reception of these stations.
Where to Listen Online
Other Resources
Propagation, Time of Day, and Location
