Militia Radio Frequencies
Revision as of 13:18, 21 August 2020 by R4002 (Talk | contribs)
new page, placeholder for now.
MURS and FRS form the backbone of the VHF tactical and command networks used by militia groups. The 22 FRS channels are used in addition to the 5 MURS channels. Because FRS is on the UHF band, it performs better for inter squad and intra squad radio compared to VHF. FRS considerably outperforms MURS in urban environments. MURS, however, offers greater range on a watt-for-watt basis. CB and 11 meter frequencies will give the best range (especially in rural areas). Base stations with CB and VHF (MURS) capability are recommended for command and control. Handheld militia radios should be programmed with the 5 MURS channels and the 22 FRS channels at a minimum.
This includes the Baofeng UV-5R series, UV-82 series, UV-82HP, etc.
T-CTCS should be set for transmit only. R-CTCS should be set to OFF. In CHIRP, the tone mode is Tone, not TSQL. All frequencies with the exception MURS 4 (154.570 MHz) and MURS 5 (154.600 MHz) should be set to NFM (narrow) mode. MURS 4 and MURS 5 should be set to FM (wide) mode. On a manually programmed radio, NFM is NARR and FM is WIDE.
  • Channel 001 - FRS 1 - 462.5625 MHz Mode: NFM - Tone 67.0Hz - display FRS1
  • Channel 002 - FRS 2 - 462.5875 MHz Mode: NFM - Tone 118.8Hz - display FRS2
  • Channel 003 - FRS 3 - 462.6125 MHz Mode: NFM - Tone 127.3Hz - display FRS3
  • Channel 004 - FRS 4 - 462.6375 MHz Mode: NFM - Tone 131.8Hz - display FRS4
  • Channel 005 - FRS 5 - 462.6625 MHz Mode: NFM - Tone
  • 151.9400 MHz - Militia/Patriot VHF Primary/Calling MURS 3 - AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
  • 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
  • 154.6000 MHz - Militia/Patriot VHF MURS 5
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business
  • 154.505 MHz - VHF Business
  • 154.515 MHz - VHF Business
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business
  • 154.625 MHz - VHF Business
  • 154.655 MHz - VHF Business
