By far the most active ranges are 43 meters (6765-7000 kHz), 49 meters (6100-6400 kHz) and 70 meters (4000-4100 kHz), with some activity in the 60 meter band (4700-5300 kHz) as well.
Last updated: May 2020
| 3390 kHz | AM/USB - used by Old Time Radio in February 2019 and March 2019 |
| 4015 kHz | AM/USB |
| 4020 kHz | AM/USB |
| 4025 kHz | AM/USB |
| 4060 kHz | AM/USB |
| 4065 kHz | AM/USB |
| 4080 kHz | AM/USB |
| 5100 kHz | AM - reported in use June 2019 |
| 6770 kHz | AM - used by Old Time Radio or OTR, considered to be OTR's "home channel" |
| 6840 kHz | AM |
| 6850 kHz | usually AM |
| 6855 kHz | usually AM |
| 6868 kHz | AM/USB - noted use by Mix Radio International (May 2019) |
| 6870 kHz | AM/USB |
| 6885 kHz | AM/USB |
| 6886 kHz | AM/USB |
| 6890 kHz | AM/USB |
| 6915 kHz | AM/USB |
| 6920 kHz | AM/USB |
| 6925 kHz | most common frequency - virtually all modes have been heard +/- 1-2 kHz Many pirate radio listeners park receivers on 6925 kHz. |
| 6930 kHz | AM/USB |
| 6935 kHz | AM/USB - Latin American pirates can also be heard here (i.e. AD149 on 6934.8 kHz or 6934.9 kHz AM) |
| 6945 kHz | AM/USB |
| 6950 kHz | AM/USB |
| 6955 kHz | AM/USB |
| 6965 kHz | AM/USB |
| 6970 kHz | AM |
| 6995 kHz | AM/SSB - noted used by KUNT |
| 7465 kHz | AM - noted use by YHWH religious pirate |
| 7470 kHz | AM - noted use by YHWH religious pirate (June 2019) |
| 7480 kHz | AM - noted use by YHWH religious pirate (May 2019) |
| 13560 kHz | AM - Old Time Radio daytime frequency - logged June 2019 |
Euro-Pirate Radio Frequencies
- 3920-3950 (75 meters)
- 9500-10200 kHz
- 7400-8100 kHz
- 6765-7000 kHz
- 5000-6300 kHz
- 8000 kHz - Radio Casa
- 6925.1 kHz - RCW Chile
- 6250 - Used in the 1980s
- Return to Pirate Radio New Listener Guide and FAQ
- Return to Where Can I Find Pirate Activity
- Go to Pirate radio stations
- Go to A Brief Survey of HF Receiving Equipment
