Revision as of 19:27, 30 August 2020 by Ka3jjz (Talk | contribs)
By far the most active ranges are 43 meters (6765-7000 kHz), 49/46 meters (6100-6400 kHz) and 70 meters (4000-4100 kHz), with some activity in the 60 meter band (4700-5300 kHz) as well.
Last updated: August 2020
3390 kHz AM/USB - used by Old Time Radio in February 2019 and March 2019
4015 kHz AM/USB
4020 kHz AM/USB
4025 kHz AM/USB
4060 kHz AM/USB
4065 kHz AM/USB
4080 kHz AM/USB
5100 kHz AM - reported in use June 2019
6770 kHz AM - used by Old Time Radio or OTR, considered to be OTR's "home channel"
6840 kHz AM
6850 kHz usually AM
6855 kHz usually AM
6868 kHz AM/USB - noted use by Mix Radio International (May 2019)
6870 kHz AM/USB
6885 kHz AM/USB
6886 kHz AM/USB
6890 kHz AM/USB
6915 kHz AM/USB
6920 kHz AM/USB
6925 kHz most common frequency - virtually all modes have been heard +/- 1-2 kHz Many pirate radio listeners park receivers on 6925 kHz.
6930 kHz AM/USB
6935 kHz AM/USB - Latin American pirates can also be heard here (i.e. AD149 on 6934.8 kHz or 6934.9 kHz AM)
6945 kHz AM/USB
6950 kHz AM/USB
6955 kHz AM/USB
6965 kHz AM/USB
6970 kHz AM
6995 kHz AM/SSB - noted used by KUNT
7465 kHz AM - noted use by YHWH religious pirate
7470 kHz AM - noted use by YHWH religious pirate (June 2019)
7480 kHz AM - noted use by YHWH religious pirate (May 2019)
13560 kHz AM - Old Time Radio daytime frequency - logged June 2019
15070 kHz active in the early 1990's by Europirates and pirates in North America, but recently quiet due to the low solar cycle
While 6925 and nearby frequencies remain popular, the above chart makes very clear that numerous other frequencies have become more active in recent years. Frequencies around 5100-5200 khz (58 meters) and 4000-4200 khz (70 meters) have become more and more common. These ranges are not exclusive to US pirates - Europirates and even some Latin Americans have shown up in these ranges. Recently Europirates have shown up in the 3900-3950 khz band - this is the 75 Meter amateur phone band. Some have even shown in in the SWBC bands, including 49, 31 and 25 meters.
  • 6250 - Used in the 1980s
The 43 meter band (6750-7000 kHz) is also heavily used by so-called "peskies" (a play on the Spanish term "pescadores - meaning "fishermen"), stations engaging in two-way radio chatter in Portuguese, Spanish and other languages (including English). Peskies generally use LSB mode. 6925 kHz LSB is one of the most active peskie frequencies, which can cause serious interference issues for pirates operating in AM mode on 6925 kHz or adjacent frequencies. The area around 6900 kHz (including 6895 kHz and 6905 kHz) are also heavily used by Spanish-speaking stations in both USB and LSB modes. Other pirates deliberately interfere with pescadore/freebander communications. There are indications that some, if not most, of the so-called "peskies" are actually land-based stations operating on bootleg frequencies, much like 11 meter freebanders operate above and below the legal 40-channel CB band. The "peskies' have shown up in the following places;
  • 9500-10200 kHz
  • 7400-8100 kHz
  • 6765-7000 kHz
  • 5000-6300 kHz
You can find loggings of Latin American Pirates here.
Some examples of Latin American Pirates
  • 8000 kHz - Radio Casa
  • 6925.1 kHz - RCW Chile
