Wi-Fi
Wireless LAN / Wi-Fi WiFi frequency bands UHF and higher.
900 MHz (802.11ah)
802.11ah operates in sub-gigahertz unlicensed bands. Each world region supports different sub-bands, and the channels number depends on the starting frequency of the sub-band it belongs to. Thus, there is no global channels numbering plan, and the channels numbers are incompatible between world regions (and even between sub-bands of a same world region).
| Region | Subband (MHz) | Bandwidths (MHz) |
| Australia | 915–920 | 1, 2, 4 |
| 920–928 | 1, 2, 4, 8 | |
| China | 755–779 | 1 |
| 779–787 | 1, 2, 4, 8 | |
| Europe | 863–868 | 1, 2 |
| Japan | 916.5–927.5 | 1 |
| Korea | 917.5–923.5 | 1, 2, 4 |
| New Zealand | 915–924 | 1, 2, 4, 8 |
| 924–928 | 1, 2, 4 | |
| Singapore | 866–869 | 1, 2 |
| 920–925 | 1, 2, 4 | |
| Taiwan | 839–848.5 | 1, 2, 4 |
| United States<ref>Template:Cite web</ref> | 902–904 | 1, 2 |
| 904–920 | 1, 2, 4, 8, 16 | |
2.4 GHz (802.11b/g/n/ax)
The 2.4 GHz band is extremely congested with numerous devices using this frequency band, including ISM devices, cordless telephones, Bluetooth, analog and digital wireless video link systems (video senders), baby monitors, wireless intercoms and dozens of other uses.
| Channel | F0 (MHz) | Frequency Range (MHz) | [[North America|North< | ||
| 1 | 2412 | 2401–2423 | Template:Yes | Template:Yes | Template:Yes |
| 2 | 2417 | 2406–2428 | Template:Yes | Template:Yes | Template:Yes |
| 3 | 2422 | 2411–2433 | Template:Yes | Template:Yes | Template:Yes |
| 4 | 2427 | 2416–2438 | Template:Yes | Template:Yes | Template:Yes |
| 5 | 2432 | 2421–2443 | Template:Yes | Template:Yes | Template:Yes |
| 6 | 2437 | 2426–2448 | Template:Yes | Template:Yes | Template:Yes |
| 7 | 2442 | 2431–2453 | Template:Yes | Template:Yes | Template:Yes |
| 8 | 2447 | 2436–2458 | Template:Yes | Template:Yes | Template:Yes |
| 9 | 2452 | 2441–2463 | Template:Yes | Template:Yes | Template:Yes |
| 10 | 2457 | 2446–2468 | Template:Yes | Template:Yes | Template:Yes |
| 11 | 2462 | 2451–2473 | Template:Yes | Template:Yes | Template:Yes |
| 12 | 2467 | 2456–2478 | Template:NoTemplate:Ref except CAN | Template:Yes | Template:Yes |
| 13 | 2472 | 2461–2483 | Template:NoTemplate:Ref | Template:Yes | Template:Yes |
| 14 | 2484 | 2473–2495 | Template:No | Template:YesTemplate:Ref | Template:No |
To guarantee no interference in any circumstances the Wi‑Fi protocol requires 16.25 to 22 MHz of channel separation. The remaining 2 MHz gap is used as a guard band to allow sufficient attenuation along the edge of the band. This guardband is mainly used to accommodate older routers with modem chipsets prone to full channel occupancy, as most modern Wi‑Fi modems are not prone to excessive channel occupancy. In 22 MHz channel width situations, there is 3 MHz free/unused spectrum between NON-overlapping channels, this is not called guard band but channel spacing.
3.65 GHz (802.11y)
This range is documented as only being allowed as a licensed band in the United States.
| Designation | Center (MHz) | Span | ||
| 5 MHz | 10 MHz | 20 MHz | ||
| 131 | 3657.5 | 3655–3660 | ||
| 3660 | 3655–3665 | |||
| 132 | 3662.5 | 3660–3665 | ||
| 3665 | 3655–3675 | |||
| 133 | 3667.5 | 3665–3670 | ||
| 3670 | 3665–3675 | |||
| 134 | 3672.5 | 3670–3675 | ||
| 135 | 3677.5 | 3675–3680 | ||
| 3680 | 3675–3685 | |||
| 136 | 3682.5 | 3680–3685 | ||
| 3685 | 3675–3695 | |||
| 137 | 3687.5 | 3685–3690 | ||
| 3690 | 3685–3695 | |||
| 138 | 3692.5 | 3690–3695 | ||
| Text | Meaning |
| Template:Yes | MAY be used without restrictions. |
| Template:No | SHOULD NOT be used. |
| Template:Yes | MUST be used indoor only. |
| Template:Yes | MUST be used with DFS regardless indoor or outdoor. |
| Template:Yes | MUST comply with SRD requirements regardless indoor or outdoor. |
| Template:Yes | MUST be used with DFS and indoor only. |
| Template:Yes | MUST be used with TPC and indoor only. |
| Template:Yes | MUST be used with DFS and TPC. |
| Template:Yes | MUST be used with DFS, TPC and comply with SRD requirements. |
| Template:Yes | MUST be used with DFS, TPC and indoor only. |
| Template:Nonfree | MUST be used only after registration. |
| Template:Unknown | Information not available or defined. |
| Notes: Template:Citation | |
Germany requires DFS and TPC capabilities on 5.250–5.350 GHz and 5.470–5.725 GHz as well; in addition, the frequency range 5.150–5.350 GHz is allowed only for indoor use, leaving only 5.470–5.725 GHz for outdoor and indoor use.<ref name="Germany">Template:Cite web</ref>
Since this is the German implementation of EU Rule 2005/513/EC, similar regulations must be expected throughout the European Union.<ref name="eur-lex1">Template:Cite web</ref><ref name="eur-lex2">Template:Cite web</ref>
European standard EN 301 893 covers 5.15–5.725 GHz operation, and Template:As of v2.1.1 has been adopted.<ref>Template:Cite web</ref>
Austria
Austria adopted Decision 2005/513/EC directly into national law.<ref name="Austria">Template:Cite web</ref> The same restrictions as in Germany apply, only 5.470–5.725 GHz is allowed to be used outdoor and indoor.
South Africa
Source for South Africa: <ref name="South-Africa" />
Japan's use of 10 and 20 MHz-wide 5 GHz wireless channels is codified by Association of Radio Industries and Businesses (ARIB) document STD-T71, Broadband Mobile Access Communication System (CSMA).<ref>Template:Cite web</ref> Additional rule specifications relating to 40, 80, and 160 MHz channel allocation has been taken on by Japan's Ministry of Internal Affairs and Communications (MIC).<ref name="auto">Template:Cite web</ref>
Brazil
In Brazil, the TPC use in 5.150–5.725 GHz band is optional. DFS is required only in the 5.470–5.725 GHz band.<ref name="Brazil-DFS">Template:Cite web</ref>
Singapore
Singapore regulatory – IMDA requires DFS and TPC capabilities on 5.250–5.350 GHz above 100 mW effective radiated powerand below or equal to 200 mW EIRP, requires DFS capability on 5.250–5.350 GHz below or equal to 100 mW EIRP, and requires DFS and TPC capabilities on 5.470–5.725 below or equal to 1000 mW EIRP. Operating 5.725–5.850 GHz above 1000 mW and below or equal to 4000 mW EIRP shall be approved on exceptional basis.<ref name="Singapore IDA" />
South Korea
Indonesia
5.9 GHz (802.11p)
6 GHz (802.11ax)
On 23 April 2020, the FCC voted to allocate 1.2 GHz of unlicensed spectrum in the 6 GHz band (5.925–7.125 GHz) for Wi-Fi use.
| Band | 20 MHz | 40 MHz | 80 MHz | 160 MHz |
| U-NII-5 | 24 | 12 | 6 | 3 |
| U-NII-6 | 5 | 2.5 | 1.25 | 0.5 |
| U-NII-7 | 17.5 | 8.75 | 4.25 | 2.25 |
| U-NII-8 | 12.5 | 5.75 | 2.5 | 1.25 |
| TOTAL | 59 | 29 | 14 | 7 |
Standard power
| U-NII-6 | Not allowed | |||
| U-NII-7 | 17 | 8 | 3 | 1 |
| U-NII-8 | Not Allowed | |||
| TOTAL | 41 | 20 | 9 | 4 |
Very-low-power devices
Client devices
Europe
The European Commission is expected to rule on 6 GHz in early 2021. It is currently expected that EU regulations will permit operation only in the band from 5925 to 6425 MHz (corresponding to the US U-NII-5 band) by low-power indoor and very-low-power devices.
| 5925–6425 MHz | 24 | 12 | 6 | 3 |
60 GHz (802.11ad/ay)
