Wi-Fi
Revision as of 17:12, 15 May 2021 by R4002 (Talk | contribs)
Wireless LAN / Wi-Fi WiFi frequency bands UHF and higher.
900 MHz (802.11ah)
It is important to note that the 902-928 MHz band is allocated to numerous other services, including 33cm amateur radio band, cordless telephone systems, vehicle transponder systems, train and railroad telemetry systems and unlicensed frequency hopping spread spectrum (FHSS) business radio systems.
Region ↓ Subband
(MHz) ↓
Bandwidths
(MHz) ↓
Australia 915–920 MHz 1, 2, 4
920–928 MHz 1, 2, 4, 8
China 755–779 MHz 1
779–787 MHz 1, 2, 4, 8
Europe 863–868 MHz 1, 2
Japan 916.5–927.5 MHz 1
Korea 917.5–923.5 MHz 1, 2, 4
New
Zealand
915–924 MHz 1, 2, 4, 8
924–928 MHz 1, 2, 4
Singapore 866–869 MHz 1, 2
920–925 MHz 1, 2, 4
Taiwan 839–848.5 MHz 1, 2, 4
United States 902–904 MHz 1, 2
904–920 MHz 1, 2, 4, 8, 16
2.4 GHz (802.11b/g/n/ax)
The 2.4 GHz band is extremely congested in many areas with numerous devices using this frequency band, including high power ISM devices, cordless telephones, Bluetooth, analog and digital wireless video link systems (video senders), baby monitors, wireless intercoms, wireless microphone systems, short-range data and audio/video link systems of various power output levels and bandwidths...along with dozens of other uses.
The availability of the 5 GHz band for WLAN / WiFi applications, the 5.8 GHz band for cordless telephones and the 1.9 GHz DECT band for cordless telephones, wireless intercoms, baby monitors, business cordless phone PBX systems, etc. means that some of the interference on 2.4 GHz could be eliminated with careful planning and frequency/channel use coordination among local users.
Channel F0 (MHz) Frequency
Range
(MHz)
1 2412 2401–2423
2 2417 2406–2428
3 2422 2411–2433
4 2427 2416–2438
5 2432 2421–2443
6 2437 2426–2448
7 2442 2431–2453
8 2447 2436–2458
9 2452 2441–2463
10 2457 2446–2468
11 2462 2451–2473
12 2467 2456–2478
13 2472 2461–2483
14 2484 2473–2495
To guarantee no interference in any circumstances the Wi‑Fi protocol requires 16.25 to 22 MHz of channel separation. The remaining 2 MHz gap is used as a guard band to allow sufficient attenuation along the edge of the band. This guardband is mainly used to accommodate older routers with modem chipsets prone to full channel occupancy, as most modern Wi‑Fi modems are not prone to excessive channel occupancy. In 22 MHz channel width situations, there is 3 MHz free/unused spectrum between NON-overlapping channels, this is not called "guard band" but channel spacing.
3.65 GHz (802.11y)
Designation Center
(MHz)
Span
5 MHz 10 MHz 20 MHz
131 3657.5 3655–3660
3660 3655–3665
132 3662.5 3660–3665
3665 3655–3675
133 3667.5 3665–3670
3670 3665–3675
134 3672.5 3670–3675
135 3677.5 3675–3680
3680 3675–3685
136 3682.5 3680–3685
3685 3675–3695
137 3687.5 3685–3690
3690 3685–3695
138 3692.5 3690–3695
Channel Center
Frequency
(MHz)
Frequency
Range
(MHz)
10
MHz
20
MHz
40
MHz
80
MHz
160
MHz
United
States
FCC
U-NII Band(s)
United
States
<ref>Template:Cite web</ref>
Canada
Europe
Russia
India
Template:Citation needed
Singa-
pore
Mainland China
Israel
Korea
Turkey
South Africa
Brazil
<ref name=Brazil/>
Taiwan
New
Zealand
Bahrain
Vietnam
Channel Center
Frequency
(MHz)
Frequency
Range
(MHz)
10
MHz
20
MHz
40
MHz
80
MHz
160
MHz
FCC
U-NII Band(s)
Notes: Template:Notefoot
Caption
Text Meaning
Notes: Template:Citation
Germany requires DFS and TPC capabilities on 5.250–5.350 GHz and 5.470–5.725 GHz as well; in addition, the frequency range 5.150–5.350 GHz is allowed only for indoor use, leaving only 5.470–5.725 GHz for outdoor and indoor use.
Austria
The same restrictions as in Germany apply, only 5.470–5.725 GHz is allowed to be used outdoor and indoor.
Brazil
In Brazil, the TPC use in 5.150–5.725 GHz band is optional. DFS is required only in the 5.470–5.725 GHz band.
Singapore
Singapore regulatory – IMDA requires DFS and TPC capabilities on 5.250–5.350 GHz above 100 mW effective radiated powerand below or equal to 200 mW EIRP, requires DFS capability on 5.250–5.350 GHz below or equal to 100 mW EIRP, and requires DFS and TPC capabilities on 5.470–5.725 below or equal to 1000 mW EIRP (1 watt) Operating 5.725–5.850 GHz above 1000 mW (1 watt) and below or equal to 4000 mW (4 watts) EIRP shall be approved on exceptional basis.
South Korea
Indonesia
5.9 GHz (802.11p)
6 GHz (802.11ax)
On 23 April 2020, the FCC voted to allocate 1.2 GHz of unlicensed spectrum in the 6 GHz band (5.925–7.125 GHz) for Wi-Fi use. This represents a significant increase in available spectrum bandwidth for broadband wireless applications. It also provides for the possibility of moving larger networks off of the heavily congested 2.4 GHz and 5 GHz bands.
U-NII-5 24 12 6 3
U-NII-6 5 2.5 1.25 0.5
U-NII-7 17.5 8.75 4.25 2.25
U-NII-8 12.5 5.75 2.5 1.25
TOTAL 59 29 14 7
Standard power
U-NII-5 24 12 6 3
U-NII-6 Not allowed
U-NII-7 17 8 3 1
U-NII-8 Not Allowed
TOTAL 41 20 9 4
Very-low-power devices
Client devices
Europe
The European Commission is expected to rule on 6 GHz in early 2021. It is currently expected that EU regulations will permit operation only in the band from 5925 to 6425 MHz 5.925 GHz to 6.425 GHz (corresponding to the US U-NII-5 band) by low-power indoor and very-low-power devices.
EU 6 GHz Channels
5925–6425 MHz 24 12 6 3
60 GHz (802.11ad/ay)
