Revision as of 12:40, 16 September 2021 by R4002 (Talk | contribs)
VHF low band VHF-low
  • 39.4600 MHz - LLAW1D - Simplex (156.7 Hz PL transmit tone only)
  • 39.4600 MHz - LLAW1 - Repeater, paired with 45.8600 MHz (input) (156.7 Hz PL)
  • 39.4800 MHz - LFIRE2D - Simplex (156.7 Hz PL transmit tone only)
  • 39.4800 MHz - LFIRE2 - Repeater, paired with 45.8800 MHz (input) (156.7 Hz PL)
  • 45.8600 MHz - LLAW3D - Simplex (156.7 Hz PL transmit tone only)
  • 45.8600 MHz - LLAW3 - Repeater, paired with 39.4600 MHz (input) (156.7 Hz PL)
  • 45.8800 MHz - LFIRE4D - Simplex (156.7 Hz PL transmit tone only)
  • 45.8800 MHz - LFIRE4 - Repeater, paired with 39.4800 MHz (input) (156.7 Hz PL
VHF high band VHF band
  • 155.1600 MHz - VSAR16 or NATSAR - Search and Rescue - simplex CTCSS 127.3 Hz (CSQ receive recommended)
  • 155.3400 MHz - VMED28 - Ambulance to Hospital/Hospital to Hospital, medical interop - HEAR or HEAR340 (various CTCSS tones)
  • 154.2800 MHz - VFIRE21 - Fire Interop - Primary
UHF band
*UHF MED Channels - UHF EMS Channels *Original Channel Plan (25 kHz channels, 12.5 kHz bandwidth)
  • 462.9500 MHz - MED-9 - Calling/Dispatch, repeater paired with 467.9500 MHz
  • 462.9750 MHz - MED-10 - Calling/Dispatch, repeater paired with 467.9750 MHz
  • 463.0000 MHz - MED-1 - EMS Operations, repeater paired with 468.0000 MHz
  • 463.0250 MHz - MED-2 - EMS Operations, repeater paired with 468.0250 MHz
  • 463.0500 MHz - MED-3 - EMS Operations, repeater paired with 468.0500 MHz
  • 463.0750 MHz - MED-4 - EMS Operations, repeater paired with 468.0750 MHz
  • 463.1000 MHz - MED-5 - EMS Operations, repeater paired with 468.1000 MHz
  • 463.1250 MHz - MED-6 - EMS Operations, repeater paired with 468.1250 MHz
  • 463.1500 MHz - MED-7 - EMS Operations, repeater paired with 468.1500 MHz
  • 463.1750 MHz - MED-8 - EMS Operations, repeater paired with 468.1750 MHz
  • 462.9625 MHz - MED-92 - Calling/Dispatch, repeater paired with 467.9625 MHz
  • 462.9875 MHz - MED-102 - Calling/Dispatch, repeater paired with 467.9875 MHz
  • 463.0125 MHz - MED-12 - EMS Operations, repeater paired with 468.0125 MHz
  • 463.0375 MHz - MED-22 - EMS Operations, repeater paired with 468.0375 MHz
  • 463.0625 MHz - MED-32 - EMS Operations, repeater paired with 468.0625 MHz
  • 463.0875 MHz - MED-42 - EMS Operations, repeater paired with 468.0875 MHz
  • 463.1125 MHz - MED-52 - EMS Operations, repeater paired with 468.1125 MHz
  • 463.1375 MHz - MED-62 - EMS Operations, repeater paired with 468.1375 MHz
  • 463.1625 MHz - MED-72 - EMS Operations, repeater paired with 468.1625 MHz
  • 463.1875 MHz - MED-82 - EMS Operations, repeater paired with 468.1875 MHz
  • 462.95625 MHz - MED-91 - EMS Operations, repeater paired with 467.95625 MHz
  • 462.96875 MHz - MED-93 - EMS Operations, repeater paired with 467.96875 MHz
  • 462.98125 MHz - MED-101 - EMS Operations, repeater paired with 467.98125 MHz
  • 462.99375 MHz - MED-103 - EMS Operations, repeater paired with 467.99375 MHz
  • 463.00625 MHz - MED-11 - EMS Operations, repeater paired with 468.00625 MHz
  • 463.01875 MHz - MED-13 - EMS Operations, repeater paired with 468.01875 MHz
  • 463.03125 MHz - MED-21 - EMS Operations, repeater paired with 468.03125 MHz
  • 463.04375 MHz - MED-23 - EMS Operations, repeater paired with 468.04375 MHz
  • 463.05625 MHz - MED-31 - EMS Operations, repeater paired with 468.05625 MHz
  • 463.06875 MHz - MED-33 - EMS Operations, repeater paired with 468.06875 MHz
  • 463.08125 MHz - MED-41 - EMS Operations, repeater paired with 468.08125 MHz
  • 463.09375 MHz - MED-43 - EMS Operations, repeater paired with 468.09375 MHz
  • 463.10625 MHz - MED-51 - EMS Operations, repeater paired with 468.10625 MHz
  • 463.11875 MHz - MED-53 - EMS Operations, repeater paired with 468.11875 MHz
  • 463.13125 MHz - MED-61 - EMS Operations, repeater paired with 468.13125 MHz
  • 463.14375 MHz - MED-63 - EMS Operations, repeater paired with 468.14375 MHz
  • 463.15625 MHz - MED-71 - EMS Operations, repeater paired with 468.15625 MHz
  • 463.16875 MHz - MED-73 - EMS Operations, repeater paired with 468.16875 MHz
  • 463.18125 MHz - MED-81 - EMS Operations, repeater paired with 468.18125 MHz
  • 463.19375 MHz - MED-83 - EMS Operations, repeater paired with 468.19375 MHz
700 MHz band
  • 769.24375 MHz - 7CALL50/7CALL50D - Calling, simplex or repeater (input: 799.24375 MHz) TX 293 NAC, RX F7E NAC
  • 773.25625 MHz - 7CALL70/7CALL70D - Calling (secondary), simplex or repeater (input: 803.25625 MHz) TX 293 NAC, RX F7E NAC
  • 769.14375 MHz - 7TAC51/7TAC51D - General Use, simplex or repeater (input: 799.14375 MHz) TX 293 NAC, RX F7E NAC
  • 769.64375 MHz - 7TAC52/7TAC52D - General Use, simplex or repeater (input: 799.64375 MHz) TX 293 NAC, RX F7E NAC
  • 770.14375 MHz - 7TAC53/7TAC53D - General Use, simplex or repeater (input: 800.14375 MHz) TX 293 NAC, RX F7E NAC
  • 770.64375 MHz - 7TAC54/7TAC54D - General Use, simplex or repeater (input: 800.64375 MHz) TX 293 NAC, RX F7E NAC
  • 769.74375 MHz - 7TAC55/7TAC55D - General Use, simplex or repeater (input: 799.74375 MHz) TX 293 NAC, RX F7E NAC
  • 770.24375 MHz - 7TAC56/7TAC56D - General Use, simplex or repeater (input: 800.24375 MHz) TX 293 NAC, RX F7E NAC
  • 770.99375 MHz - 7TAC57/7TAC57D - General Use, simplex or repeater (input: 800.99375 MHz) TX 293 NAC, RX F7E NAC
  • 770.89375 MHz - 7MOB59/7MOB59D - Mobile Repeater, simplex or repeater (input: 800.89375 MHz) TX 293 NAC, RX F7E NAC
  • 770.39375 MHz - 7LAW61/7LAW61D - Law Enforcement, simplex or repeater (input: 800.39375 MHz) TX 293 NAC, RX F7E NAC
  • 770.49375 MHz - 7LAW62/7LAW62D - Law Enforcement, simplex or repeater (input: 800.49375 MHz) TX 293 NAC, RX F7E NAC
  • 769.89375 MHz - 7FIRE63/7FIRE63D - Fire, simplex or repeater (input: 799.89375 MHz) TX 293 NAC, RX F7E NAC
  • 769.99375 MHz - 7FIRE64/7FIRE64D - Fire, simplex or repeater (input: 799.99375 MHz) TX 293 NAC, RX F7E NAC
  • 769.39375 MHz - 7MED65/7MED65D - EMS, simplex or repeater (input: 799.39375 MHz) TX 293 NAC, RX F7E NAC
  • 769.49375 MHz - 7MED66/7MED66D - EMS, simplex or repeater (input: 799.49375 MHz) TX 293 NAC, RX F7E NAC
  • 770.74375 MHz - 7DATA69/7DATA69D - Data, simplex or repeater (input: 800.74375 MHz) TX 293 NAC, RX F7E NAC
  • 773.10625 MHz - 7TAC71/7TAC71D - General Use, simplex or repeater (input: 803.10625 MHz) TX 293 NAC, RX F7E NAC
  • 773.60625 MHz - 7TAC72/7TAC72D - General Use, simplex or repeater (input: 803.60625 MHz) TX 293 NAC, RX F7E NAC
  • 774.10625 MHz - 7TAC73/7TAC73D - General Use, simplex or repeater (input: 804.10625 MHz) TX 293 NAC, RX F7E NAC
  • 774.60625 MHz - 7TAC74/7TAC74D - General Use, simplex or repeater (input: 804.60625 MHz) TX 293 NAC, RX F7E NAC
  • 773.75625 MHz - 7TAC75/7TAC75D - General Use, simplex or repeater (input: 803.75625 MHz) TX 293 NAC, RX F7E NAC
  • 774.25625 MHz - 7TAC76/7TAC76D - General Use, simplex or repeater (input: 804.25625 MHz) TX 293 NAC, RX F7E NAC
  • 774.85625 MHz - 7TAC77/7TAC77D - General Use, simplex or repeater (input: 804.85625 MHz) TX 293 NAC, RX F7E NAC
  • 774.50625 MHz - 7MOB79/7MOB79D - Mobile Repeater, simplex or repeater (input: 804.50625 MHz) TX 293 NAC, RX F7E NAC
  • 774.00625 MHz - 7LAW81/7LAW81D - Law Enforcement, simplex or repeater (input: 804.00625 MHz) TX 293 NAC, RX F7E NAC
  • 774.35625 MHz - 7LAW82/7LAW82D - Law Enforcement, simplex or repeater (input: 804.35625 MHz) TX 293 NAC, RX F7E NAC
  • 773.50625 MHz - 7FIRE83/7FIRE83D - Fire, simplex or repeater (input: 803.50625 MHz) TX 293 NAC, RX F7E NAC
  • 773.85625 MHz - 7FIRE84/7FIRE84D - Fire, simplex or repeater (input: 803.85625 MHz) TX 293 NAC, RX F7E NAC
  • 773.00625 MHz - 7MED86/7MED86D - EMS, simplex or repeater (input: 803.00625 MHz) TX 293 NAC, RX F7E NAC
  • 773.35625 MHz - 7MED87/7MED87D - EMS, simplex or repeater (input: 803.35625 MHz) TX 293 NAC, RX F7E NAC
  • 774.75625 MHz - 7DATA89/7DATA89D - Data, simplex or repeater (input: 804.75625 MHz) TX 293 NAC, RX F7E NAC
  • 769.13125 MHz - 7AG58/7AG58D - Air-to-Ground, simplex or repeater (input: 799.13125 MHz) TX 293 NAC, RX F7E NAC
  • 769.63125 MHz - 7AG60/7AG60D - Air-to-Ground, simplex or repeater (input: 799.63125 MHz) TX 293 NAC, RX F7E NAC
  • 770.13125 MHz - 7AG67/7AG67D - Air-to-Ground, simplex or repeater (input: 800.13125 MHz) TX 293 NAC, RX F7E NAC
  • 770.63125 MHz - 7AG68/7AG68D - Air-to-Ground, simplex or repeater (input: 800.63125 MHz) TX 293 NAC, RX F7E NAC
  • 773.11875 MHz - 7AG78/7AG78D - Air-to-Ground, simplex or repeater (input: 803.11875 MHz) TX 293 NAC, RX F7E NAC
  • 773.61875 MHz - 7AG80/7AG80D - Air-to-Ground, simplex or repeater (input: 803.61875 MHz) TX 293 NAC, RX F7E NAC
  • 774.11875 MHz - 7AG85/7AG85D - Air-to-Ground, simplex or repeater (input: 804.11875 MHz) TX 293 NAC, RX F7E NAC
  • 774.61875 MHz - 7AG88/7AG88D - Air-to-Ground, simplex or repeater (input: 804.61875 MHz) TX 293 NAC, RX F7E NAC
800 MHz band
  • 851.0125 MHz - 8CALL90D/8CALL90 - Calling, simplex or repeater (input: 806.0125 MHz) both with 156.7 Hz CTCSS
  • 851.5125 MHz - 8TAC91D/8TAC91 - Tac 1, simplex or repeater (input: 806.5125 MHz) both with 156.7 Hz CTCSS
  • 852.0125 MHz - 8TAC92D/8TAC92 - Tac 2, simplex or repeater (input: 807.0125 MHz) both with 156.7 Hz CTCSS
  • 852.5125 MHz - 8TAC93D/8TAC93 - Tac 3, simplex or repeater (input: 807.5125 MHz) both with 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 808.5125 MHz) both with 156.7 Hz CTCSS
  • 853.4875 MHz - old 800 MHz itinerant channel, may be used for simplex, tactical or talkaround purposes.
UHF band
  • Law Enforcement Plan
  • LE A Calling - 167.0875 MHz
  • LE B Calling - 414.0375 MHz
  • LE 01 Tactical - 162.0875 MHz
  • LE 02 Tactical - 162.2625 MHz
  • LE 03 Tactical - 162.8375 MHz
  • LE 04 Tactical - 163.2875 MHz
  • LE 05 Tactical - 163.4250 MHz
  • LE 06 Tactical - 167.2500 MHz
  • LE 07 Tactical - 167.7500 MHz
  • LE 08 Tactical - 168.1125 MHz
  • LE 09 Tactical - 168.4625 MHz
  • LE 10 Tactical - 418.9875 MHz
  • LE 11 Tactical - 419.1875 MHz
  • LE 12 Tactical - 419.6125 MHz
  • LE 13 Tactical - 414.0625 MHz
  • LE 14 Tactical - 414.3125 MHz
  • LE 15 Tactical - 414.3375 MHz
  • LE 16 Tactical - 409.9875 MHz
  • LE 17 Tactical - 410.1875 MHz
  • LE 18 Tactical - 410.6125 MHz
  • Incident Response Plan
  • NC 1 Calling - 164.7125 MHz
  • NC 2 Calling - 419.2375 MHz
  • IR 01 - 165.2500 MHz
  • IR 02 - 165.9625 MHz
  • IR 03 - 166.5750 MHz
  • IR 04 - 167.3250 MHz
  • IR 05 - 169.5375 MHz
  • IR 06 - 170.0125 MHz
  • IR 07 - 170.4125 MHz
  • IR 08 - 170.6875 MHz
  • IR 09 - 173.0375 MHz
  • IR 10 - 419.4375 MHz
  • IR 11 - 419.6375 MHz
  • IR 12 - 419.8375 MHz
  • IR 13 - 413.1875 MHz
  • IR 14 - 413.2125 MHz
  • IR 15 - 410.2375 MHz
  • IR 16 - 410.4375 MHz
  • IR 17 - 410.6375 MHz
  • IR 18 - 410.8375 MHz
  • 2182 kHz - USB voice - SAR operations - marine distress/calling
  • 3023 kHz - USB voice - SAR operations - marine, military
  • 4125 kHz - USB voice - SAR operations - marine distress/calling
  • 5680 kHz - USB voice - SAR operations
  • 6215 kHz - USB voice - SAR operations - marine distress/calling
  • 8291 kHz - USB voice - SAR operations - marine distress/calling
  • 8364 kHz - USB voice - SAR operations
  • 10003 kHz - USB voice - SAR operations
  • 12290 kHz - USB voice - SAR operations - marine distress/calling
  • 14993 kHz - USB voice - SAR operations
  • 16420 kHz - USB voice - SAR operations - marine distress/calling
  • 19993 kHz - USB voice - SAR operations
  • 40.5000 MHz - FM Guard - FM SINCGARS military emergency use only - Fox Guard or Fox Mike Guard 40.5 MHz
  • 121.5000 MHz - VHF Guard - VHF aircraft emergency use only - Victor Guard 121.5 MHz
  • 243.0000 MHz - UHF Guard - UHF aircraft emergency use only - Uniform Guard 243.0 MHz
  • 155.1600 MHz - SAR Ground Operations (127.3 Hz CTCSS transmit recommended, CSQ receive strongly recommended)
  • 155.3400 MHz - EMS/Medical Support
  • 123.1000 MHz - AM air-to-air (civilian)
  • 282.8000 MHz - AM air-to-air military SAR scene of action working channel
  • 345.0000 MHz - AM military USCG SAR calling
  • 156.8000 MHz - Marine hailing/calling DISTRESS ONLY (VHF marine channel 16)
  • 157.0500 MHz - Ground-to-marine assets SAR working channel (VHF marine channel 21A)
  • 157.0500 MHz - Marine operations, under authority of USCG Sector Commander (VHF marine channel 21A)
  • 157.1500 MHz - Marine operations, under authority of USCG Sector Commander (VHF marine channel 23A)
  • 157.1750 MHz - Ground-to-air SAR working channel (VHF marine channel 83A)
  • 122.8500 MHz - AM air rescue asset coordination
  • 122.9000 MHz - AM air rescue asset coordination
  • 123.0250 MHz - AM air rescue asset coordination
  • 123.0500 MHz - AM air rescue asset coordination
  • 123.0750 MHz - AM air rescue asset coordination - fixed-wing aircraft
  • 156.8500 MHz - SAR Command interop (VHF marine channel 17) - with USCG Sector Commander
  • 410.8375 MHz - IR 12 - SAR Command Federal/Non-Federal repeater (paired with 419.8375 MHz) - 167.9 Hz CTCSS
  • 159.4725 MHz - VTAC14 - SAR Command interop (VHF) - 156.7 Hz CTCSS
  • 453.8625 MHz - UTAC43D - SAR Command interop simplex (UHF) - 156.7 Hz CTCSS
  • 453.8625 MHz - UTAC43 - SAR Command interop repeater (paired with 458.8625 MHz) - 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94D - SAR Command interop simplex - 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94 - SAR Command interop repeater (paired with 808.0125 MHz) - 156.7 Hz CTCSS
National Interagency Fire Center - NIFC Radio Cache National Incident Radio Support Cache - NIRSC. Forest fire firefighting wildfire fighting radio communications support. Includes extensive VHF aircraft band capability, remote links (using UHF) for portable/temporary VHF repeater networks, mountaintop VHF aircraft band]] VHF-AM base station kits (with UHF remote linking) and other go-kits for setting up an entire radio communications network in a remote area with limited or no radio communications infrastructure. Use of the 163.100 MHz and 168.350 MHz government common "work" channels is included in their plan as well as numerous VHF-AM airband frequencies.
  • 168.6250 MHz - Nationwide AIR GUARD - Must be included for air-to-ground communications - 110.9 Hz CTCSS required
  • 168.6500 MHz - Nationwide Flight Following - National Flight Following frequency, interagency aircraft contact - 110.9 Hz CTCSS required
Oil Spill Cleanup
