RHA68
RHA68 - VHF FM license free radio service - Finland only. Similar to the Thailand 78 MHz VHF CB allocation, Italian 43 MHz VHF 43 CB service, the Swedish 31 MHz JAKT Radio 31 MHz hunting radio service and Swedish 69 MHz mid-band 69 MHz VHF CB service VHF mid band 66-88 MHz band, FM voice. Very close to the 70 MHz (4-metre) amateur (ham) radio band.
FM voice, appears to be standard 4 kHz FM deviation or 5 kHz FM deviation - 16K0F3E or 20K0F3E emission, 25 kHz channels. Odd channel numbering sequence.
VHF mid band - or VHF low band depending on who you ask - channels 67.500 MHz to 72.325 MHz FM - middle of the band is 70 MHz, cf. 72 MHz, 74 MHz and 75 MHz. Falls above and below the 70 MHz or 4-meter amateur band (where available). Finland authorizes 70.0 MHz to 70.3 MHz as the 4 meter band. RHA68 channel 13 (70.200 MHz) falls within this allocation.
Like other license-free services (such as 11-meter 27 MHz CB or 27MHz LA Radio or LA-Phone or PMR446) RHA68 is popular with radio hobbyists as well as private individuals, hunting clubs, businesses, outdoor organizations, hikers, backpackers, hunters, outdoorsman, farmers, taxi drivers, rideshare drivers (Uber, Lyft, etc.) and numerous other groups.
- Channel 1 / 1A - 68.1000 MHz
- Channel 2 / 2A - 68.3000 MHz
- Channel 3 / 3A - 68.4250 MHz
- Channel 4 / 4A - 68.5250 MHz
- Channel 5 / 5E - 68.0500 MHz
- Channel 6 / 6E - 68.5750 MHz
- Channel 7 / 7E - 68.1750 MHz
- Channel 8 / 8E - 67.5000 MHz
- Channel 9 / 9E - 71.3750 MHz
- Channel 10 / 10E - 71.4250 MHz
- Channel 11 / 11E - 71.4750 MHz
- Channel 12 / 12E - 71.6250 MHz
- Channel 13 / 13E - 70.2000 MHz
- Channel 14 / 14E - 71.0250 MHz
- Channel 15 / 15E - 71.0500 MHz
- Channel 16 / 16E - 71.1000 MHz
- Channel 17 / 17A - 68.2250 MHz
- Channel 18 / 18E - 68.3750 MHz
- Channel 19 / 19E - 71.1750 MHz
- Channel 20 / 20E - 71.7500 MHz
- Channel 21 / 21E - 71.9000 MHz
- Channel 22 / 22E - 71.3500 MHz
- Channel 23 / 23E - 71.5500 MHz
- Channel 24 / 24E - 71.5750 MHz
- Channel 25 / 25E - 71.6000 MHz
- Channel 26 / 26E - 72.3250 MHz
Channel group A
| Channel | Frequency | Usage | Power limit |
| 1 | 68.1000 MHz | Roadside assistance organizations | 25 W |
| 2 | 68.3000 MHz | Motor sports | 25 W |
| 3 | 68.4250 MHz | Voluntary rescue service | 25 W |
| 4 | 68.5250 MHz | Motor sports | 25 W |
| 17 | 68.2250 MHz | Voluntary rescue service | 25 W |
Channel group E
| 5 | 68.0500 MHz | General use | 5 W |
| 6 | 68.5750 MHz | General use | 5 W |
| 7 | 68.1750 MHz | General use | 5 W |
| 8 | 67.5000 MHz | General use | 5 W |
| 9 | 71.3750 MHz | General use | 5 W |
| 10 | 71.4250 MHz | General use | 5 W |
| 11 | 71.4750 MHz | General use | 5 W |
| 12 | 71.6250 MHz | General use | 5 W |
| 13 | 70.2000 MHz | General use | 5 W |
| 14 | 71.0250 MHz | General use | 5 W |
| 15 | 71.0500 MHz | General use | 25 W |
| 16 | 71.1000 MHz | General use | 25 W |
| 18 | 68.3750 MHz | General use | 25 W |
| 19 | 71.1750 MHz | General use | 25 W |
| 20 | 71.7500 MHz | General use | 25 W |
| 21 | 71.9000 MHz | General use | 25 W |
| 22 | 71.3500 MHz | General use | 5 W |
| 23 | 71.5500 MHz | General use | 5 W |
| 24 | 71.5750 MHz | General use | 5 W |
| 25 | 71.6000 MHz | General use | 5 W |
| 26 | 72.3250 MHz | General use | 5 W |
Relation to 4m amateur radio band (70 MHz band). The RHA68 frequencies fall within the 66-88 MHz VHF mid band (sometimes called "VHF low band" or "VHFL". The 4 meter ham radio band also falls within this spectrum. The 66-88 MHz spectrum is used for land mobile two-way radio in many areas. It is used for broadcasting as part of the OIRT FM band (65.9 MHz to 74 MHz) in Russia and Eastern Europe. Interference from OIRT FM broadcasters is possible. The lower part of VHF mid band falls within the original Band I broadcasting band plan (47 MHz to 68 MHz) for FM radio and TV broadcasting.
