SINCGARS
Revision as of 12:37, 8 February 2023 by R4002 (Talk | contribs)
For example:
  • Relay Operation:
  • Repeater Operation:
Background and History
60.000 MHz to 80.000 MHz TBS "Talk Between Ships" - VHF 60-80 MC 60-80 MHz Ship to Ship voice radio 60-80 MC radio - US Navy AM mode 50w output VHF Crystal controlled 60-80 MHz AM voice unknown channel spacing - TBS radio crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) - note 27.0 MHz, 27.1 MHz, 27.2 MHz up to 27.9 MHz overlap 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) - note 38.0 MHz, 38.1 MHz, 38.2 MHz up to 38.9 MHz overlap 100 kHz (channels 380-549), PRC-10, PRC-10A
40.000 MHz to 48.000 MHz American Infantry Band - portable VHF FM tactical radios - WWII vintage 200 kHz - channel 0 = 40.0 MHz, channel 40 = 48.0 MHz, SCR-300 (BC-1000) manpack backpack radio
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) 50 kHz channels - AM voice with FM characteristics, close air support and tank command nets
20.000 MHz to 52.000 MHz Soviet / Eastern Bloc USSR R-111 (low band: 20-36 MHz, high band: 36-52 MHz) High power (75w) Russian FM tank radio
20.000 MHz to 22.375 MHz Soviet / Eastern Bloc USSR R-113 (25 kHz channel steps, 96 channels) Medium power (16w) Russian FM tank radio
20.000 MHz to 51.500 MHz Soviet / Eastern Bloc USSR R-123 R-123M (low band: 20-35.75 MHz, high band: 35.75-51.5 MHz) Medium power (20w) Russian FM tank radio
20.000 MHz to 69.975 MHz Yugoslavian tank radio - exported widely, 25 kHz channel steps) Medium power (30w) FM tank radio
20.000 MHz to 49.975 MHz Chinese FM tank radio (example Type 889 radio) - widely exported - 25 kHz channel steps Chinese clone of Russian 20-50 MHz tank radios (such as the R-113 or P-113) - FM voice, 25 kHz channels 3w low 20w high RF power
30.000 MHz to 75.950 MHz Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 family using the RT-246/VRC RT-246A RT-542 RT-542/VRC RT-542A/VRC radio sets - AN/VRC-12, VRC-43, VRC-44, VRC-45, VRC-46, VRC-47, VRC-48, VRC-49 Jeep radios, etc. and dozens of others
30 MHz to 512 MHz Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands, REMBASS 138.025 MHz to 152.975 MHz (25 kHz steps) - sometimes listed as 30-511.99 MHz or 30.000 MHz to 511.995 MHz 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps
2400-2500 MHz (2.4 GHz) Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems - including the Personal Role Radio (PRR) Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
  • 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
Confirmed 30-88 MHz and 30-50 MHz FM Military Frequencies
These operate basically as de facto beacons.
