SINCGARS
For example:
- Relay Operation:
- Channel 1 - TX and RX 30.150 MHz - mountaintop or other elevated position - connected to Channel 2 radio
- Channel 2 - TX and RX 49.850 MHz - mountaintop or other elevated position - connected to Channel 1 radio
- Repeater Operation:
- Channel 1 - TX 32.375 MHz - mountaintop or other elevated position
- Channel 1 - RX 41.700 MHz - mountaintop or other elevated position
Background and History
| 60.000 MHz to 80.000 MHz | TBS "Talk Between Ships" - VHF 60-80 MC 60-80 MHz Ship to Ship voice radio 60-80 MC radio - US Navy AM mode 50w output VHF | Crystal controlled 60-80 MHz AM voice unknown channel spacing - TBS radio crystals for 65.74 MHz and 72.50 MHz have been found |
| 27.000 MHz to 38.900 MHz | American Artillery Band (U.S. Army) - note 27.0 MHz, 27.1 MHz, 27.2 MHz up to 27.9 MHz overlap | 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628 |
| 38.000 MHz to 54.900 MHz | American Infantry Band (U.S. Army) - note 38.0 MHz, 38.1 MHz, 38.2 MHz up to 38.9 MHz overlap | 100 kHz (channels 380-549), PRC-10, PRC-10A |
| 40.000 MHz to 48.000 MHz | American Infantry Band - portable VHF FM tactical radios - WWII vintage | 200 kHz - channel 0 = 40.0 MHz, channel 40 = 48.0 MHz, SCR-300 (BC-1000) manpack backpack radio |
| 3500 kHz to 6000 kHz | SCR-536 Handheld Radio 3.5 MHz to 6.0 MHz the "walkie-talkie" - actually called a Handie-Talkie or HT | Crystal controlled, 360mw AM voice only - short range tactical communications HF AM |
| 3800 kHz to 6500 kHz | SCR-694 3.8 MHz to 6.5 MHz AM, CW or MCW - portable or vehicle-mounted tactical AM voice, tone or straight CW | Crystal controlled, 10-20 mile range (voice, R/T), 20-40 miles range (tone, W/T) depending on antenna used |
| 3800 kHz to 5800 kHz | SCR-284 3.8 MHz to 5.8 MHz AM, CW or MCW - transportable or vehicle-mounted tactical AM voice, tone or straight CW | 24 watts transmit power (CW mode, W/T), 17 watts transmit power voice (W/T, AM voice) |
| 2000 kHz to 8000 kHz | Wireless Set No. 19 - British tank radio 2-8 MHz with very low power VHF "B" set built in, 229-241 MHz | Tank to tank command usage (A set - 2-8 MHz) and very short range tank communications (B set) |
| 47.000 MHz to 55.400 MHz | American Infantry Band - portable tactical radios - Korea War vintage - PRC-6 | AN/PRC-6 "banana radio" walkie talkie portable single-channel crystal controlled FM radio, 250mw output, 47-55.4 MHz FM |
| 27.200 MHz to 33.300 MHz | German Armor Tank Radio Panzer Radio Band - sometimes listed as 27.0 MHz - 33.4 MHz or 27.2 MHz - 33.4 MHz | 50 kHz channels - AM voice - this was, by far, the most common tank command/tactical radio band used |
| 42.000 MHz to 48.300 MHz | German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) | 50 kHz channels - AM voice with FM characteristics, close air support and tank command nets |
| 28.000 MHz to 33.000 MHz | German Infantry Band (portable radios) | 100 kHz channels, actual coverage 27.8 MHz to 33.2 MHz |
| 32.000 MHz to 38.000 MHz | German Infantry Band (portable radios) | 100 kHz channels - Feldfu d and KL.Fuspr.d manpack portable infantry radios |
| 33.800 MHz to 38.000 MHz | German Infantry Band (transportable portable radios - higher power command sets) | 100 kHz channels |
| 20.000 MHz to 52.000 MHz | Soviet / Eastern Bloc USSR R-111 (low band: 20-36 MHz, high band: 36-52 MHz) | High power (75w) Russian FM tank radio |
| 20.000 MHz to 22.375 MHz | Soviet / Eastern Bloc USSR R-113 (25 kHz channel steps, 96 channels) | Medium power (16w) Russian FM tank radio |
| 20.000 MHz to 51.500 MHz | Soviet / Eastern Bloc USSR R-123 R-123M (low band: 20-35.75 MHz, high band: 35.75-51.5 MHz) | Medium power (20w) Russian FM tank radio |
| 20.000 MHz to 69.975 MHz | Yugoslavian tank radio - exported widely, 25 kHz channel steps) | Medium power (30w) FM tank radio |
| 20.000 MHz to 49.975 MHz | Chinese FM tank radio (example Type 889 radio) - widely exported - 25 kHz channel steps | Chinese clone of Russian 20-50 MHz tank radios (such as the R-113 or P-113) - FM voice, 25 kHz channels 3w low 20w high RF power |
| 30.000 MHz to 75.950 MHz | Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control | 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 family using the RT-246/VRC RT-246A RT-542 RT-542/VRC RT-542A/VRC radio sets - AN/VRC-12, VRC-43, VRC-44, VRC-45, VRC-46, VRC-47, VRC-48, VRC-49 Jeep radios, etc. and dozens of others |
| 30 MHz to 512 MHz | Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands, REMBASS 138.025 MHz to 152.975 MHz (25 kHz steps) - sometimes listed as 30-511.99 MHz or 30.000 MHz to 511.995 MHz | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps |
| 2400-2500 MHz (2.4 GHz) | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems - including the Personal Role Radio (PRR) | Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams |
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
For additional information, see the Business Radio (Business Band) land mobile radio service page - including the VHF low band subsection.
- 30.000 MHz - 30.560 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate air-to-ground and air-to-air communication systems in this band for tactical and training operations. The federal agencies operate land mobile radio communication systems in this band to support natural resource management and wildlife telemetry.
- 30.560 MHz - 32.000 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - The military agencies operate communication systems in this band for tactical and training operations. The federal agencies operate land mobile radio communication systems in this band to support natural resource management and forest fire fighting. Inter-operable communications are used to support mutual aid response with local public safety agencies. 30.56 MHz to 31.98 MHz (20 kHz steps), allocated for state government (forestry) and business/industrial land mobile services.
- 32.000 MHz - 33.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support for tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communications systems in this band to support land management and to protect natural resources.
- 33.000 MHz - 34.000 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - The federal agencies operate land mobile radio communication systems in this band to support mutual aid response with local public safety agencies. The military agencies operate communication systems in this band for tactical and training operations. They also operate tactical air-to-ground and air-to-air communications systems for close air support missions. 33.02 MHz to 33.98 MHz (20 kHz steps), allocated for local government (33 MHz fire radio band) and some limited business/industrial land mobile services (33.34 MHz, 33.4 MHz, etc.).
- 34.000 MHz - 35.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support. The federal agencies operate land mobile radio communication systems in this band to support law enforcement and facilities security management, natural resource management, park security law enforcement at national parks, forests, and wildlife refuge areas.
- 35.000 MHz - 36.000 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - 35.02 MHz to 35.98 MHz land mobile business and industrial radio systems, local paging systems. The military agencies operate communication systems in this band on a non-interference basis for tactical and training operations.
- 36.000 MHz - 37.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems in this band for military close air support missions. The federal agencies operate land mobile radio communication systems in this band to support national park management, law enforcement, public safety nets, contingencies, and natural resources management.
- 37.000 MHz - 37.500 MHz - Non-Federal and Federal - LAND MOBILE - 37.02 MHz to 37.5 MHz (20 kHz channel steps) public safety, law enforcement, and business/industrial land mobile systems. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis.
- 37.500 MHz - 38.000 MHz - Non-Federal and Federal - LAND MOBILE, RADIO ASTRONOMY - The National Science Foundation uses this band to perform radio astronomy research into continuum observations to study electromagnetic radiation from the planet Jupiter and from the Sun.
- 38.000 MHz - 38.250 MHz - Federal - FIXED, MOBILE, RADIO ASTRONOMY - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The Coast Guard operates ship-to-ship and ship-to-shore communication systems in this band. The National Science Foundation uses this band to perform radio astronomy research into continuum observations to study electromagnetic radiation from the planet Jupiter and from the Sun.
- 38.250 MHz - 39.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate communication systems for combat net radio operations to provide command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems for the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support law enforcement, public safety operations, control of power generation transmission and water facilities, environmental data collection, fish management, and wildlife telemetry programs.
- 39.000 MHz - 40.000 MHz - Non-Federal and Federal - LAND MOBILE - 39.02 MHz to 39.98 MHz (20 kHz channel steps) used for local and state police communications, interoperability and other emergency services. Federal agencies operate land mobile radio communications systems to support public safety responses to local communities. The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support for tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions.
- 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
- 42.000 MHz - 43.690 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - 42.00 MHz to 42.94 MHz (20 kHz channel steps) state police radio systems (supplanted or replaced by VHF high band, UHF or 700 MHz/800 MHz digital trunking systems in many states). Business and industrial land mobile systems operate between 42.96 MHz and 43.68 MHz. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis.
- 43.690 MHz - 46.600 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - 43.70 MHz to 46.58 MHz (20 kHz channel steps) public safety, law enforcement, and business/industrial land mobile systems. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis.
- 46.600 MHz - 47.000 MHz - Federal - FIXED, LAND MOBILE - The military agencies operate radio communication systems in this band for combat net radio operations to provide command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air radio communication systems for close air support missions. The federal agencies operate land mobile radio communication systems in this band for contingency response to various national disasters, national resources management, law enforcement, tornado tracking, and various meteorological research programs.
- 47.000 MHz - 49.600 MHz - Non-Federal and Federal - LAND MOBILE - 47.02 MHz to 49.58 MHz (20 kHz channel steps) public safety, law enforcement, and business/industrial land mobile systems. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis. The National Aeronautics and Space Administration (NASA) use this band to research and observe wind shear conditions for spacecraft
- 49.600 MHz - 50.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for combat net radio operations to provide command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air radio communication systems for close air support missions. The federal agencies operate land mobile radio communication systems in this band for contingency response to various national disasters, national resources management, law enforcement, tornado tracking, and various meteorological research programs.
- 50.000 MHz - 54.000 MHz - Non-Federal and Federal - AMATEUR - 6 meter amateur radio band. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 54.000 MHz - 72.000 MHz - Non-Federal and Federal - BROADCASTING. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 72.000 MHz - 73.000 MHz - Non-Federal and Federal - FIXED, MOBILE - The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis. 72.02 MHz - 72.98 MHz is an operational fixed band for business, industrial users. This band is also shared with the 72 MHz RC frequencies (72.01 MHz to 75.99 MHz).
- 73.000 MHz - 74.600 MHz - Federal - RADIO ASTRONOMY, FIXED, MOBILE - The National Science Foundation uses this band to perform radio astronomy research via continuum observations to identify characteristics of stars, planets, and gases such as their elemental composition, temperature, etc. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 74.600 MHz - 74.800 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate land mobile radio communication systems used by military aircraft crews. The federal agencies operate portable-to-portable communication and low-power communication systems that are used inside power plant facilities to remotely control devices. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 74.800 MHz - 75.200 MHz - Federal - AERONAUTICAL RADIONAVIGATION - The Federal Aviation Administration operates Instrument Landing System (ILS) marker beacons in this band to provide navigational guidance information during aircraft approach and landing on 75.0 MHz. 74.8 - 75.2 MHz guard band.
- 75.200 MHz - 75.400 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies use this band for fixed and mobile radio communications. Typical uses are runway light control systems and communication to aircrews. The federal agencies use this band for land mobile radio communications for public safety operations, low power operations to the remote control of mechanical devices, and other uses.
- 75.400 MHz - 76.000 MHz - Non-Federal and Federal - FIXED, MOBILE - The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis. 75.4 MHz - 75.98 MHz is an operational fixed band for business, industrial users. This band is also shared with the 75 MHz RC frequencies (75.41 MHz to 75.99 MHz).
- 76.000 MHz - 88.000 MHz - Non-Federal and Federal - BROADCASTING. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 34.100 MHz - 41.700 MHz Ra120 Swedish manpack portable VHF FM tactical radio, 100 kHz steps
- PRC-6 - 47.00 MHz to 55.40 MHz (crystal controlled, single channel)
- PRC-8 and PRC-8A - 20.00 MHz to 27.90 MHz (100 kHz steps, continuous tuning)
- PRC-9 and PRC-9A - 27.00 MHz to 38.90 MHz (100 kHz steps, continuous tuning)
- PRC-10 and PRC-10A - 38.00 MHz to 54.90 MHz (100 kHz steps, continuous tuning)
- PRC-25 30.00 MHz to 75.95 MHz (50 kHz steps, channelized) - 150 Hz tone squelch
- PRC-77 30.00 MHz to 75.95 MHz (50 kHz steps, channelized) - 150 Hz tone squelch
- VRC-12 30.00 MHz to 75.95 MHz (50 kHz steps, channelized) - 150 Hz tone squelch or carrier squelch
- VRC-8 20.00 MHz to 27.90 MHz (100 kHz steps, continuous tuning) - RT-66 FM transceiver
- VRC-9 27.00 MHz to 38.90 MHz (100 kHz steps, continuous tuning) - RT-67 FM transceiver
- VRC-10 39.00 MHz to 54.90 MHz (100 kHz steps, continuous tuning) - RT-68 FM transceiver
Confirmed 30-88 MHz and 30-50 MHz FM Military Frequencies In Use North America USA
Some of these are active enough to operate basically as de facto VHF low band beacons.
Most military bases have a few VHF FM frequencies that are used for range control, aircraft control or advisory and other purposes. These are published frequencies and are not tactical in nature. The tactical frequencies are changed on a regular basis and often either the LMR (UHF P25 trunking systems in the 380-399.9 MHz range), frequency hopping (30-88 MHz range). Aircraft communications will be found in the UHF band, plus the 137-144 MHz and 148-150.8 MHz military VHF AM band (which is shared with military land mobile users). Many military bases will have their control tower simulcast on UHF airband (225-400 MHz) with VHF airband (usually 126.200 MHz) and sometimes a FM frequency (VHF low band).
Work still in progress, list will be forthcoming.
