DDE
Revision as of 12:29, 14 June 2023 by R4002 (Talk | contribs)
Technical Specifications
12.5 kHz spacing, NFM 11K0F3E, 11K0F1D, 11K0F2D and 11K0F3D emission types. Voice and data. CTCSS (PL) tone squelch and in-band audio-frequency multi-tone selective calling (SELCALL) in extensive use. 35 MHz French PMR radio.
ePMR LMR PMR PLMR VHF low band land mobile radio system. The VHF low band spectrum is used by numerous other services, including other services in France and elsewhere in Europe, military FM, paging networks, public safety two-way radio systems, AM (DSB) 40MHz DSB fishery radiotelephone fishing fleet fishery radio networks, FM radiotelephone fishery radio systems, data link, remote control or "telecommand" and various other uses worldwide.
Band Plan - Channelization Frequency List Channel List Frequency Pairs
  • Mobile RX (Repeater Output) / Mobile TX (Repeater Input)
  • 35.0750 MHz / 39.4750 MHz - Channel 13
  • 35.0875 MHz / 39.4875 MHz - Channel 14
  • 35.1000 MHz / 39.5000 MHz - Channel 15
  • 35.1125 MHz / 39.5125 MHz - Channel 16
  • 35.1250 MHz / 39.5250 MHz - Channel 17
  • 35.1375 MHz / 39.5375 MHz - Channel 18
  • 35.1500 MHz / 39.5500 MHz - Channel 19
  • 35.1625 MHz / 39.5625 MHz - Channel 20
  • 35.1750 MHz / 39.5750 MHz - Channel 21
  • 35.1875 MHz / 39.5875 MHz - Channel 22
  • 35.2000 MHz / 39.6000 MHz - Channel 23
  • 35.2125 MHz / 39.6125 MHz - Channel 24
  • 35.2250 MHz / 39.6250 MHz - Channel 25
  • 35.2375 MHz / 39.6375 MHz - Channel 26
  • 35.2500 MHz / 39.6500 MHz - Channel 27
  • 35.2625 MHz / 39.6625 MHz - Channel 28
Additional French VHF low 30-50 MHz and VHF mid band 66-88 MHz PMR PLMR LMR spectrum allocations:
12.5 kHz spacing
  • 30.8750 MHz - 32.1250 MHz - Simplex
  • 32.6000 MHz - 33.0000 MHz - Simplex
  • 34.8500 MHz - 34.9000 MHz - Simplex
  • 34.9000 MHz - 36.2500 MHz - Repeater outputs (duplex) systems - including DDE PMR
  • 36.2500 MHz - 36.6000 MHz - Simplex
  • 36.8625 MHz - 39.1000 MHz - Simplex
  • 39.3000 MHz - 40.6500 MHz - Repeater inputs (paired with 34.9 MHz - 36.25 MHz) - DDE PMR
  • 68.4625 MHz - 69.2500 MHz - Repeater inputs (paired with 72.5125 MHz - 73.3 MHz) - EDF and GDF PMR
  • 70.2500 MHz - 70.5250 MHz - Simplex
  • 70.9750 MHz - 71.9500 MHz - Simplex
  • 72.5125 MHz - 73.3000 MHz - Repeater outputs (duplex) systems - including EDF and GDF
  • 75.2000 MHz - 75.3000 MHz - Simplex
  • 75.3000 MHz - 77.4750 MHz - Repeater outputs (duplex - paired with 80.3 MHz - 82.475 MHz)
  • 80.0000 MHz - 80.3000 MHz - Simplex
  • 80.3000 MHz - 82.4750 MHz - Repeater inputs (paired with 75.3 MHz - 77.475 MHz)
