Pescadores
Contents[hide] |
General
Freebanders on HF
- 200 meters: 1600-1800 kHz - AM mode (used in Russia and Eastern Europe)
- 150 meters: 2000-2200 kHz - AM/SSB modes (common in Russia and Eastern Europe, mix of land based and marine mobile AM traffic)
- 120 meters: 2300-2500 kHz - AM mode - Russia and Eastern Europe (see also: 100 meters or 3 MHz region)
- 100 meters: 2500-3500 kHz - AM mode (old military radios and marine radios) with some SSB - very busy in Russia and Eastern Europe CIS - "Troyka"
- 70 meters: 4000-4100 kHz
- 45 meters: 6400-6700 kHz - 6.6 MHz band, EC, Echo Charlie band or 45 metros/45 meters
- 43 meters: 6765-7000 kHz
- 41 meters/39 meters: 7300 kHz + up into the 8195-8815 kHz marine band
- 30 meters/29 meters: roughly 10300 kHz to 10500 kHz or 10600 kHz. 10445 kHz USB, 10450 kHz USB, 10455 kHz USB, 10460 kHz USB - very popular in Russia
- 22 meters: 13500-14000 kHz
Updated April 2023
- 14654.5 kHz USB - Spanish
- 10460 kHz USB - Russian
- 10455 kHz USB - Russian
- 10450 kHz USB - Russian
- 10445 kHz USB - Russian
- 10440 kHz USB - Russian
- 10400 kHz USB - Russian
- 10222.2 kHz USB - Spanish
- 10022.2 kHz USB - Spanish
- 10008.8 kHz USB - Spanish
- 9191.9 kHz USB - Spanish language - another "cute frequency" (easy to remember)
- 9161 kHz USB - Spanish language (also logged on 9161.3 kHz USB)
- 9055.5 kHz USB - Spanish
- 8959 kHz USB - Spanish
- various frequencies in the 7300 kHz to 8000 kHz range (8000 kHz to 8815 kHz is the 8 MHz SSB marine band)
- 6980 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6970 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6966 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6959 kHz USB - "The Angry Bahstads" Fishermen out of New England (possibly Boston or Gloucestermen), on numerous other freqs
- 6925 kHz LSB - Portuguese
- 6919 kHz LSB - Portuguese
- 6900 kHz USB - Spanish
- 6885 kHz USB - Spanish
- 6870 kHz USB - Fishing fleets out of Gloucester, MA (English language, one of many frequencies)
- 6695.5 kHz USB and 6696.6 kHz USB - Spanish (similar to 6666.6 kHz)
- 6670 kHz USB - alternate to 6666.6 USB
- 6666.6 kHz USB - 45 metros calling frequency - home channel similar to 6900 LSB
- 6666.6 kHz LSB - Spanish bootleg traffic here in addition to 6666.6 kHz USB
- 6516 kHz USB - English language heard here, US based fishing trawlers (ITU HF marine channel 606)
- 6212.2 kHz USB - The Angry Bahstads - New England fishing fleets, very "salty language" (also 6212 kHz USB, 6095 kHz USB, 6959 kHz USB)
- 6212 kHz USB - New English fishing fleets - "The Angry Bahstads"
- 6095 kHz USB - New England fishing fleets (operating out of band, outside the 6200 kHz to 6525 kHz 6 MHz marine band)
- 5555.5 kHz USB - Spanish
- 5555 kHz LSB - English
- 5515 kHz USB - Spanish
- 5500 kHz USB - Spanish
- 5430 kHz USB - Spanish
- 3155 kHz AM - Russian - variable frequency
- 3150 kHz AM - Russian - very drifty, variable frequency - 3152 kHz, 3153 kHz, 3150 kHz, 3154.4 kHz and so on
- 3030 kHz AM - Russian
- 3000 kHz AM - Russian
- 2990 kHz AM - Russian
- 2975 kHz AM - Russian - very drifty - any frequency between 2700 kHz and 3300 kHz
- 2970 kHz AM - Russian
- 2930 kHz USB - Russian trawlers fishing boats 2-3 MHz around 3 MHz
- 2920 kHz USB - Russian trawlers fishing boats 2-3 MHz around 3 MHz
- 2910 kHz USB - Russian trawlers fishing boats 2-3 MHz around 3 MHz
- 1600 kHz - 4000 kHz - the 2-4 MHz region is home to legal marine allocations, but many bootleg operations may also be found here, sometimes in AM mode (especially in Eastern Europe, Russia and the CIS countries/former Soviet Union) - with most activity centered roughly around 3.000 MHz (cf. 2910 kHz, 2920 kHz, etc. USB, and offset frequencies like 3005 kHz 3.005 MHz, 3017 kHz 3.017 MHz, 3020 kHz 3033 kHz 3.034 MHz etc.
USA Fishermen
- 4009 kHz USB Mentions of New Bedford, last logged 19 Feb 2023.
- 6959 kHz USB Mentions of New Bedford, last logged 18 Feb 2023.
- 6319.5 kHz USB last logged 2 Feb 2023.
- 8393.3 kHz USB last logged 2 Feb 2023.
- 8396 kHz USB last logged 1 Feb 2023.
- 4876.5 kHz USB last logged 1 Feb 2023.
- 6144.5 kHz USB last logged 29 Jan 2023.
- 6282 kHz USB last logged 19 Jan 2023.
- 4378 kHz USB they also use 8296, last logged 30 Dec 2022.
- 8296 kHz USB last logged 30 Dec 2022.
- 6263.5 kHz USB last logged 29 Dec 2022.
- 4508 kHz USB Perhaps CT/Long Island area, last logged 19 Dec 2022.
- Return to List of Pirate Radio Frequencies
