HF marine
See also: VHF marine band
| Band | Frequency Range |
| 2450-2850 kHz | MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-4 MHz AM mode, many users operate outside this band, roughly around 3 MHz) |
| 16360-17460 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 25070-25121 kHz | HF 25 MHz marine band - the 25 MHz and 26 MHz bands are shared with land mobile and fixed/mobile services |
| 26145-26175 kHz | HF 26 MHz marine band - shared with fixed mobile services, including ocean-based telemetry systems |
| 26175-30000 kHz | Various CB-like marine allocations found in this region (some SSB marine radios stop at 27500 kHz or 27.500 MHz instead of 29.999 MHz) |
DSC should not be confused with DCS, digital coded squelch, a selective calling squelch system used on VHF/UHF land mobile radio systems.
- 2182 kHz Voice - no longer monitored by USCG, still monitored by private and commercial vessels and shore stations worldwide
- 2187.5 kHz DSC
- 4125 kHz Voice SSB
- 4207.5 kHz DSC
- 6215 kHz Voice
- 6312 kHz DSC
- 8291 kHz Voice
- 8414 kHz DSC
- 12290 kHz Voice
- 12577 kHz DSC
- 16420 kHz Voice
- 16804.5 kHz DSC
- 3023 kHz USB - Voice SAR on-scene coordination / communications
- 5680 kHz USB - Voice SAR on-scene coordination / communications
- 8364 kHz USB - Voice SAR on-scene coordination / communications
- 10003 kHz USB - Voice SAR on-scene coordination / communications
- 14993 kHz USB - Voice SAR on-scene coordination / communications
SSB Sailing Net Frequencies
- 6215 kHz USB - Caribbean Net 10:00 UTC - 12:00 UTC
- 4045 kHz USB - Caribbean Weather Center Net 10:40 UTC
- 8137 kHz USB - Caribbean Weather Center Net 10:40 UTC
- 4036 kHz USB - Ocean Cruising Club Net Primary 11:00 UTC - July - mid September
- 6227 kHz USB - Ocean Cruising Club Net Secondary 11:00 UTC - July - mid September
- 8137 kHz USB - Caribbean Weather Center Net 11:30 UTC
- 12350 kHz USB - Caribbean Weather Center Net 11:30 UTC
- 8170 kHz USB - Coconut Telegraph Net Primary 12:00 UTC
- 8146 kHz USB - Coconut Telegraph Net Secondary 12:00 UTC
- 8164 kHz USB - Coconut Telegraph Net Alternate 12:00 UTC
- 8104 kHz USB - Seven Seas Cruising Association SSCA Net - "KPA" - 12:15 UTC
- 8170 kHz USB - Cruiseheimers Net Primary 12:30 UTC
- 8146 kHz USB - Cruiseheimers Net Secondary 12:30 UTC
- 8164 kHz USB - Cruiseheimers Net Secondary 12:30 UTC
- 8137 kHz USB - Caribbean Weather Center Net 12:30 UTC
- 12350 kHz USB - Caribbean Weather Center Net 12:30 UTC
- 6209 kHz USB - Southwest Caribbean Net SW Caribbean Net Primary 13:15 UTC
- 6212 kHz USB - Southwest Caribbean Net SW Caribbean Net Secondary 13:15 UTC
- 6516 kHz USB - Southwest Caribbean Net SW Caribbean Net Secondary 13:15 UTC
- 2582 kHz USB - Bermuda Harbor Control Net 13:30 UTC
- 8107 kHz USB - Panama Connection Net Primary 13:30 UTC
- 8167 kHz USB - Panama Connection Net Secondary 13:30 UTC
- 6209 kHz USB - Northwest Caribbean Net NW Caribbean Net Primary 14:00 UTC
- 6212 kHz USB - Northwest Caribbean Net NW Caribbean Net Secondary 14:00 UTC
- 6516 kHz USB - Northwest Caribbean Net NW Caribbean Net Secondary 14:00 UTC
Designated Simplex Frequencies
U.S. designated frequencies in the 2 MHz - 30 MHz band are listed below. Many of these are shared with other services and may be assigned for other marine purposes per ITU rules (see below).
- 2003.0 kHz
- 2065.0 kHz
- 2079.0 kHz
- 2082.5 kHz
- 2086.0 kHz
- 2093.0 kHz
- 2096.5 kHz
- 2142.0 kHz
- 2203.0 kHz
- 2214.0 kHz
- 2635.0 kHz
- 2638.0 kHz
- 2738.0 kHz
- 2782.0 kHz
- 2830.0 kHz
- 4146.0 kHz
- 4149.0 kHz
- 4417.0 kHz
- 6224.0 kHz
- 6227.0 kHz
- 6230.0 kHz
- 6516.0 kHz
- 8294.0 kHz - Channel 8A / Channel A
- 8297.0 kHz - Channel 8B / Channel B
- 12353.0 kHz
- 12356.0 kHz
- 12359.0 kHz
- 12362.0 kHz
- 12365.0 kHz
- 16528.0 kHz
- 16531.0 kHz
- 16534.0 kHz
- 16537.0 kHz
- 16540.0 kHz
- 16543.0 kHz
- 16546.0 kHz
- 18825.0 kHz
- 18828.0 kHz
- 18831.0 kHz
- 18834.0 kHz
- 18837.0 kHz
- 18840.0 kHz
- 18843.0 kHz
- 22159.0 kHz
- 22162.0 kHz
- 22165.0 kHz
- 22168.0 kHz
- 22171.0 kHz
- 22174.0 kHz
- 22177.0 kHz
- 25100.0 kHz - Channel 25A
- 25103.0 kHz - Channel 25B
- 25106.0 kHz - Channel 25C
- 25109.0 kHz - Channel 25D
- 25112.0 kHz - Channel 25E
- 25115.0 kHz - Channel 25F
- 25118.0 kHz - Channel 25G
Simplex Frequencies - Additional
These frequencies are used for ship to ship communications and are shared with fixed/mobile services worldwide. Due to the nature of the HF spectrum allocation system, the shared frequencies are only available on the 4 MHz and 8 MHz bands
- 4 MHz band - 4000 kHz - 4060 kHz, 3 kHz spacing, USB voice
- 4000.0 kHz
- 4003.0 kHz
- 4006.0 kHz
- 4009.0 kHz
- 4012.0 kHz
- 4015.0 kHz
- 4018.0 kHz
- 4021.0 kHz
- 4024.0 kHz
- 4027.0 kHz
- 4030.0 kHz
- 4033.0 kHz
- 4036.0 kHz
- 4039.0 kHz
- 4042.0 kHz
- 4045.0 kHz
- 4048.0 kHz
- 4051.0 kHz
- 4054.0 kHz
- 4057.0 kHz
- 4057.0 kHz
- 4060.0 kHz
- 8 MHz band - 8101 kHz to 8191 kHz 3 kHz spacing, USB voice
The 7450 kHz to 8100 kHz portion of the fixed/mobile band is not included in this shared spectrum...however, many marine users use these frequencies anyway, especially the lower portion of the 8 MHz band and the higher portion of the 7 MHz band.
- 8101.0 kHz
- 8104.0 kHz
- 8107.0 kHz
- 8110.0 kHz
- 8113.0 kHz
- 8116.0 kHz
- 8119.0 kHz
- 8122.0 kHz
- 8125.0 kHz
- 8128.0 kHz
- 8131.0 kHz
- 8134.0 kHz
- 8137.0 kHz
- 8140.0 kHz
- 8143.0 kHz
- 8146.0 kHz
- 8149.0 kHz
- 8152.0 kHz
- 8155.0 kHz
- 8158.0 kHz
- 8161.0 kHz
- 8164.0 kHz
- 8167.0 kHz
- 8170.0 kHz
- 8173.0 kHz
- 8176.0 kHz
- 8179.0 kHz
- 8182.0 kHz
- 8185.0 kHz
- 8188.0 kHz
- 8191.0 kHz
These frequencies are specifically designated for duplex use (generally ship-to-shore or shore-to-ship comms). Simplex operations are very common, often using the ship frequency, but simplex ship to ship comms are found on the shore frequencies as well.
| ITU Channel | Ship Transmit / Coast Receive | Coast Transmit / Ship Receive |
| 401 | 4065 kHz | 4357 kHz |
| 402 | 4068 kHz | 4360 kHz |
| 403 | 4071 kHz | 4363 kHz |
| 404 | 4074 kHz | 4366 kHz |
| 405 | 4077 kHz | 4369 kHz |
| 406 | 4080 kHz | 4372 kHz |
| 407 | 4083 kHz | 4375 kHz |
| 408 | 4086 kHz | 4378 kHz |
| 409 | 4089 kHz | 4381 kHz |
| 410 | 4092 kHz | 4384 kHz |
| 411 | 4095 kHz | 4387 kHz |
| 412 | 4098 kHz | 4390 kHz |
| 413 | 4101 kHz | 4393 kHz |
| 414 | 4104 kHz | 4396 kHz |
| 415 | 4107 kHz | 4399 kHz |
| 416 | 4110 kHz | 4402 kHz |
| 417 | 4113 kHz | 4405 kHz |
| 418 | 4116 kHz | 4408 kHz |
| 419 | 4119 kHz | 4411 kHz |
| 420 | 4122 kHz | 4414 kHz |
| 421 | 4125 kHz | 4417 kHz |
| 422 | 4128 kHz | 4420 kHz |
| 423 | 4131 kHz | 4423 kHz |
| 424 | 4134 kHz | 4426 kHz |
| 425 | 4137 kHz | 4429 kHz |
| 426 | 4140 kHz | 4432 kHz |
| 427 | 4143 kHz | 4435 kHz |
| 601 | 6200 kHz | 6501 kHz |
| 602 | 6203 kHz | 6504 kHz |
| 603 | 6206 kHz | 6507 kHz |
| 604 | 6209 kHz | 6510 kHz |
| 605 | 6212 kHz | 6513 kHz |
| 606 | 6215 kHz | 6516 kHz |
| 607 | 6218 kHz | 6519 kHz |
| 608 | 6221 kHz | 6522 kHz |
| 801 | 8195 kHz | 8719 kHz |
| 802 | 8198 kHz | 8722 kHz |
| 803 | 8201 kHz | 8725 kHz |
| 804 | 8204 kHz | 8728 kHz |
| 805 | 8207 kHz | 8731 kHz |
| 806 | 8210 kHz | 8734 kHz |
| 807 | 8213 kHz | 8737 kHz |
| 808 | 8216 kHz | 8740 kHz |
| 809 | 8219 kHz | 8743 kHz |
| 810 | 8222 kHz | 8746 kHz |
| 811 | 8225 kHz | 8749 kHz |
| 812 | 8228 kHz | 8752 kHz |
| 813 | 8231 kHz | 8755 kHz |
| 814 | 8234 kHz | 8758 kHz |
| 815 | 8237 kHz | 8761 kHz |
| 816 | 8240 kHz | 8764 kHz |
| 817 | 8243 kHz | 8767 kHz |
| 818 | 8246 kHz | 8770 kHz |
| 819 | 8249 kHz | 8773 kHz |
| 820 | 8252 kHz | 8776 kHz |
| 821 | 8255 kHz | 8779 kHz |
| 822 | 8258 kHz | 8782 kHz |
| 823 | 8261 kHz | 8785 kHz |
| 824 | 8264 kHz | 8788 kHz |
| 825 | 8267 kHz | 8791 kHz |
| 826 | 8270 kHz | 8794 kHz |
| 827 | 8273 kHz | 8797 kHz |
| 828 | 8276 kHz | 8800 kHz |
| 829 | 8279 kHz | 8803 kHz |
| 830 | 8282 kHz | 8806 kHz |
| 831 | 8285 kHz | 8809 kHz |
| 832 | 8288 kHz | 8812 kHz |
| 1201 | 12230 kHz | 13077 kHz |
| 1202 | 12233 kHz | 13080 kHz |
| 1203 | 12236 kHz | 13083 kHz |
| 1204 | 12239 kHz | 13086 kHz |
| 1205 | 12242 kHz | 13089 kHz |
| 1206 | 12245 kHz | 13092 kHz |
| 1207 | 12248 kHz | 13095 kHz |
| 1208 | 12251 kHz | 13098 kHz |
| 1209 | 12254 kHz | 13101 kHz |
| 1210 | 12257 kHz | 13104 kHz |
| 1211 | 12260 kHz | 13107 kHz |
| 1212 | 12263 kHz | 13110 kHz |
| 1213 | 12266 kHz | 13113 kHz |
| 1214 | 12269 kHz | 13116 kHz |
| 1215 | 12272 kHz | 13119 kHz |
| 1216 | 12275 kHz | 13122 kHz |
| 1217 | 12278 kHz | 13125 kHz |
| 1218 | 12281 kHz | 13128 kHz |
| 1219 | 12284 kHz | 13131 kHz |
| 1220 | 12287 kHz | 13134 kHz |
| 1221 | 12290 kHz | 13137 kHz |
| 1222 | 12293 kHz | 13140 kHz |
| 1223 | 12296 kHz | 13143 kHz |
| 1224 | 12299 kHz | 13146 kHz |
| 1225 | 12302 kHz | 13149 kHz |
| 1226 | 12305 kHz | 13152 kHz |
| 1227 | 12308 kHz | 13155 kHz |
| 1228 | 12311 kHz | 13158 kHz |
| 1229 | 12314 kHz | 13161 kHz |
| 1230 | 12317 kHz | 13164 kHz |
| 1231 | 12320 kHz | 13167 kHz |
| 1232 | 12323 kHz | 13170 kHz |
| 1233 | 12326 kHz | 13173 kHz |
| 1234 | 12329 kHz | 13176 kHz |
| 1235 | 12332 kHz | 13179 kHz |
| 1236 | 12335 kHz | 13182 kHz |
| 1237 | 12338 kHz | 13185 kHz |
| 1238 | 12341 kHz | 13188 kHz |
| 1239 | 12344 kHz | 13191 kHz |
| 1240 | 12347 kHz | 13194 kHz |
| 1241 | 12347 kHz | 13197 kHz |
| 1601 | 16360 kHz | 17242 kHz |
| 1602 | 16363 kHz | 17245 kHz |
| 1603 | 16366 kHz | 17248 kHz |
| 1604 | 16369 kHz | 17251 kHz |
| 1605 | 16372 kHz | 17254 kHz |
| 1606 | 16375 kHz | 17257 kHz |
| 1607 | 16378 kHz | 17260 kHz |
| 1608 | 16381 kHz | 17263 kHz |
| 1609 | 16384 kHz | 17266 kHz |
| 1610 | 16387 kHz | 17269 kHz |
| 1611 | 16390 kHz | 17272 kHz |
| 1612 | 16393 kHz | 17275 kHz |
| 1613 | 16396 kHz | 17278 kHz |
| 1614 | 16399 kHz | 17281 kHz |
| 1615 | 16402 kHz | 17284 kHz |
| 1616 | 16405 kHz | 17287 kHz |
| 1617 | 16408 kHz | 17290 kHz |
| 1618 | 16411 kHz | 17293 kHz |
| 1619 | 16414 kHz | 17296 kHz |
| 1620 | 16417 kHz | 17299 kHz |
| 1621 | 16420 kHz | 17302 kHz |
| 1622 | 16423 kHz | 17305 kHz |
| 1623 | 16426 kHz | 17308 kHz |
| 1624 | 16429 kHz | 17311 kHz |
| 1625 | 16432 kHz | 17314 kHz |
| 1626 | 16435 kHz | 17317 kHz |
| 1627 | 16438 kHz | 17320 kHz |
| 1628 | 16441 kHz | 17323 kHz |
| 1629 | 16444 kHz | 17326 kHz |
| 1630 | 16447 kHz | 17329 kHz |
| 1631 | 16450 kHz | 17332 kHz |
| 1632 | 16453 kHz | 17335 kHz |
| 1633 | 16456 kHz | 17338 kHz |
| 1634 | 16459 kHz | 17341 kHz |
| 1635 | 16462 kHz | 17344 kHz |
| 1636 | 16465 kHz | 17347 kHz |
| 1637 | 16468 kHz | 17350 kHz |
| 1638 | 16471 kHz | 17353 kHz |
| 1639 | 16474 kHz | 17356 kHz |
| 1640 | 16477 kHz | 17359 kHz |
| 1641 | 16480 kHz | 17362 kHz |
| 1642 | 16483 kHz | 17365 kHz |
| 1643 | 16486 kHz | 17368 kHz |
| 1644 | 16489 kHz | 17371 kHz |
| 1645 | 16492 kHz | 17374 kHz |
| 1646 | 16495 kHz | 17377 kHz |
| 1647 | 16498 kHz | 17380 kHz |
| 1648 | 16501 kHz | 17383 kHz |
| 1649 | 16504 kHz | 17386 kHz |
| 1650 | 16507 kHz | 17389 kHz |
| 1651 | 16510 kHz | 17392 kHz |
| 1652 | 16513 kHz | 17395 kHz |
| 1653 | 16516 kHz | 17398 kHz |
| 1654 | 16519 kHz | 17401 kHz |
| 1655 | 16522 kHz | 17404 kHz |
| 1656 | 16525 kHz | 17407 kHz |
| 1801 | 18780 kHz | 19755 kHz |
| 1802 | 18783 kHz | 19758 kHz |
| 1803 | 18786 kHz | 19761 kHz |
| 1804 | 18789 kHz | 19764 kHz |
| 1805 | 18792 kHz | 19767 kHz |
| 1806 | 18795 kHz | 19770 kHz |
| 1807 | 18798 kHz | 19773 kHz |
| 1808 | 18801 kHz | 19776 kHz |
| 1809 | 18804 kHz | 19779 kHz |
| 1810 | 18807 kHz | 19782 kHz |
| 1811 | 18810 kHz | 19785 kHz |
| 1812 | 18813 kHz | 19788 kHz |
| 1813 | 18816 kHz | 19791 kHz |
| 1814 | 18819 kHz | 19794 kHz |
| 1815 | 18822 kHz | 19797 kHz |
| 2201 | 22000 kHz | 22696 kHz |
| 2202 | 22003 kHz | 22699 kHz |
| 2203 | 22006 kHz | 22702 kHz |
| 2204 | 22009 kHz | 22705 kHz |
| 2205 | 22012 kHz | 22708 kHz |
| 2206 | 22015 kHz | 22711 kHz |
| 2207 | 22018 kHz | 22714 kHz |
| 2208 | 22021 kHz | 22717 kHz |
| 2209 | 22024 kHz | 22720 kHz |
| 2210 | 22027 kHz | 22723 kHz |
| 2211 | 22030 kHz | 22726 kHz |
| 2212 | 22033 kHz | 22729 kHz |
| 2213 | 22036 kHz | 22732 kHz |
| 2214 | 22039 kHz | 22735 kHz |
| 2215 | 22042 kHz | 22738 kHz |
| 2216 | 22045 kHz | 22741 kHz |
| 2217 | 22048 kHz | 22744 kHz |
| 2218 | 22051 kHz | 22747 kHz |
| 2219 | 22054 kHz | 22750 kHz |
| 2220 | 22057 kHz | 22753 kHz |
| 2221 | 22060 kHz | 22756 kHz |
| 2222 | 22063 kHz | 22759 kHz |
| 2223 | 22066 kHz | 22762 kHz |
| 2224 | 22069 kHz | 22765 kHz |
| 2225 | 22072 kHz | 22768 kHz |
| 2226 | 22075 kHz | 22771 kHz |
| 2227 | 22078 kHz | 22774 kHz |
| 2228 | 22081 kHz | 22777 kHz |
| 2229 | 22084 kHz | 22780 kHz |
| 2230 | 22087 kHz | 22783 kHz |
| 2231 | 22090 kHz | 22786 kHz |
| 2232 | 22093 kHz | 22789 kHz |
| 2233 | 22096 kHz | 22792 kHz |
| 2234 | 22099 kHz | 22795 kHz |
| 2235 | 22102 kHz | 22798 kHz |
| 2236 | 22105 kHz | 22801 kHz |
| 2237 | 22108 kHz | 22804 kHz |
| 2238 | 22111 kHz | 22807 kHz |
| 2239 | 22114 kHz | 22810 kHz |
| 2240 | 22117 kHz | 22813 kHz |
| 2241 | 22120 kHz | 22816 kHz |
| 2242 | 22123 kHz | 22819 kHz |
| 2243 | 22126 kHz | 22822 kHz |
| 2244 | 22129 kHz | 22825 kHz |
| 2245 | 22132 kHz | 22828 kHz |
| 2246 | 22135 kHz | 22831 kHz |
| 2247 | 22138 kHz | 22834 kHz |
| 2248 | 22141 kHz | 22837 kHz |
| 2249 | 22144 kHz | 22840 kHz |
| 2250 | 22147 kHz | 22843 kHz |
| 2251 | 22150 kHz | 22846 kHz |
| 2252 | 22153 kHz | 22849 kHz |
| 2253 | 22156 kHz | 22852 kHz |
| 2501 | 25070 kHz | 26145 kHz |
| 2502 | 25073 kHz | 26148 kHz |
| 2503 | 25076 kHz | 26151 kHz |
| 2504 | 25079 kHz | 26154 kHz |
| 2505 | 25082 kHz | 26157 kHz |
| 2506 | 25085 kHz | 26160 kHz |
| 2507 | 25088 kHz | 26163 kHz |
| 2508 | 25091 kHz | 26166 kHz |
| 2509 | 25094 kHz | 26169 kHz |
| 2510 | 25097 kHz | 26172 kHz |
See also:
- VHF marine band
- Maritime Fax Transmissions
- Land Mobile Allocations 25 MHz - 30 MHz
- Chinese 480 channel HF/VHF low band 480 Channel FM fishery radiotelephone 27.500 MHz - 39.475 MHz
- Thai 10 watt / 25 watt AM FM SSB fishery marine CB radiocommunications service 168 channel 26 MHz 27 MHz
- Japanese 1 watt DSB (AM) double side band fishery radio service Japan 26-27 MHz 1W DSB 27MHz
- Japanese 25 watt SSB single side band fishery radio service Japan 27 MHz 25W SSB 27MHz
- Japanese 5 watt DSB (AM) double side band fishery radio service Japan 35.5 MHz-36 MHz and 39-40 MHz 5W DSB 40MHz
