Pescadores
General
Freebanders on HF
- 200 meters: 1600-1800 kHz - AM mode (used in Russia and Eastern Europe)
- 150 meters: 2000-2200 kHz - AM/SSB modes (common in Russia and Eastern Europe, mix of land based and marine mobile AM traffic)
- 120 meters: 2300-2500 kHz - AM mode - Russia and Eastern Europe (see also: 100 meters or 3 MHz region)
- 100 meters: 2500-3500 kHz - Centered around 3 MHz - AM mode (old military radios and marine radios) with some SSB - very busy in Russia and Eastern Europe CIS - "Troyka" or "Trioka" (Triad or triple), some SSB used. 2910 kHz USB, 2920 kHz USB calling frequencies
- 70 meters: 4000-4100 kHz
- 45 meters: 6400-6765 kHz - 6.6 MHz band, EC, Echo Charlie band or 45 metros/45 meters
- 43 meters: 6765-7000 kHz
- 41 meters/39 meters: 7300 kHz + up into the 8195-8815 kHz marine band
- 30 meters/29 meters: roughly 10300 kHz to 10500 kHz or 10600 kHz. 10445 kHz USB, 10450 kHz USB, 10455 kHz USB, 10460 kHz USB - very popular in Russia
- 22 meters: 13500-14000 kHz
- 14654.5 kHz USB - Spanish
- 10460 kHz USB - Russian
- 10455 kHz USB - Russian
- 10450 kHz USB - Russian
- 10445 kHz USB - Russian
- 10440 kHz USB - Russian
- 10400 kHz USB - Russian
- 10222.2 kHz USB - Spanish
- 10022.2 kHz USB - Spanish
- 10008.8 kHz USB - Spanish
- 9191.9 kHz USB - Spanish language - another "cute frequency" (easy to remember)
- 9161 kHz USB - Spanish language (also logged on 9161.3 kHz USB)
- 9055.5 kHz USB - Spanish
- 8959 kHz USB - Spanish
- 7733 kHz USB
- 7707 kHz USB - Arabic
- 7700 kHz USB - Asian fishermen
- 7695.5 kHz USB - Fishermen - Ireland (possibly Northern Ireland) - Irish trawlers
- various frequencies in the 7300 kHz to 8000 kHz range (8000 kHz to 8815 kHz is the 8 MHz SSB marine band)
- 6993 kHz USB - Various stations - note that this frequency is also used by the REMER Civil Defense net out of Spain (Spanish civil defense)
- 6990 kHz LSB - European stations, UNID
- 6985 kHz USB - French language
- 6980 kHz USB - "Island Peskies" - possibly out of Jamaica
- 6975 kHz USB - French language heard, also Portuguese
- 6970 kHz USB - "Island Peskies" - possibly out of Jamaica
- 6970 kHz USB - French speaking stations - heard on receivers in the UK and Europe
- 6969 kHz USB - Italian speaking stations
- 6968 kHz LSB - French and Italian language comms
- 6966 kHz USB - "Island Peskies" - possibly out of Jamaica
- 6959 kHz USB - "The Angry Bahstads" Fishermen out of New England (possibly Boston or Gloucestermen), on numerous other freqs
- 6953 kHz USB - Scottish and Irish fishermen
- 6950 kHz USB - Italian fishing boats
- 6950 kHz LSB - French speaking stations, UNID
- 6940 kHz USB - French language, possibly also fishing trawlers
- 6940 kHz LSB - German speaking stations
- 6925 kHz LSB - Portuguese
- 6920 kHz LSB - Portuguese
- 6919 kHz LSB - Portuguese
- 6910 kHz LSB - Spanish language nets
- 6900 kHz USB - Spanish
- 6885 kHz USB - Spanish
- 6876.5 kHz USB - Irish or Scottish fishermen
- 6870 kHz USB - Fishing fleets out of Gloucester, MA (English language, one of many frequencies)
- 6770 kHz USB Various languages
- 6720 kHz LSB
- 6695.5 kHz USB and 6696.6 kHz USB - Spanish (
- 6678 kHz LSB - Active frequency, French speaking freebanders
- 6670 kHz USB
- 6670 kHz LSB
- 6666 kHz LSB
- 6665 kHz LSB - Common calling / working
- 6661 kHz AM - Infrequent use, sometimes switching between AM mode and SSB (both USB and LSB noted, LSB more popular by a wide margin)
- 6660 kHz LSB - 45 meter calling - French (common) and others
- 6655 kHz LSB - 45 meter working frequency - English and French
- 6645 kHz LSB - 45 meter working frequency
- 6640 kHz LSB - 45 meter working frequency
- 6635 kHz LSB - English and French speaking freebanders
- 6633 kHz LSB - 45 meter calling - Echo Charlie
- 6630 kHz LSB
- 6623.5 kHz USB - Fishing boats - Ireland / Scotland - fishing trawlers QRM with MWARA on 6622 kHz USB
- 6600 kHz USB - UNID language,
- 6590 kHz USB - Italian speaking comms, causing QRM to MWARA allocation on 6589 kHz USB
- 6516 kHz USB - English language heard here, US based fishing trawlers (ITU HF marine channel 606)
- 6510 kHz AM - Italian
- 6212.2 kHz USB - The Angry Bahstads - New England fishing fleets, very "salty language" (also 6212 kHz USB, 6095 kHz USB, 6959 kHz USB)
- 6212 kHz USB - New English fishing fleets - "The Angry Bahstads"
- 6095 kHz USB - New England fishing fleets (operating out of band, outside the 6200 kHz to 6525 kHz 6 MHz marine band)
- 6090 kHz USB - see 6095 kHz USB above
- 5555.5 kHz USB - Spanish
- 5555 kHz LSB - English
- 5515 kHz USB - Spanish
- 5500 kHz USB - Spanish
- 5430 kHz USB - Spanish
- 3440 kHz LSB - French language, likely fishing trawlers
- 3407 kHz USB - Swedish fisheries - fishing trawlers
- 3333 kHz USB - Scottish or Irish fishing trawlers, logged in May 2024, June 2024
- 3155 kHz AM - Russian - variable frequency
- 3150 kHz AM - Russian - very drifty, variable frequency - 3152 kHz, 3153 kHz, 3150 kHz, 3154.4 kHz and so on
- 3030 kHz AM - Russian
- 3000 kHz AM - Russian
- 2990 kHz AM - Russian
- 2975 kHz AM - Russian - very drifty - any frequency between 2700 kHz and 3300 kHz
- 2970 kHz AM - Russian
- 2930 kHz USB - Russian trawlers fishing boats 2-3 MHz around 3 MHz
- 2920 kHz USB - Russian trawlers fishing boats 2-3 MHz around 3 MHz
- 2910 kHz USB - Russian trawlers fishing boats 2-3 MHz around 3 MHz
- 1600 kHz - 4000 kHz - the 2-4 MHz region is home to legal marine allocations, but many bootleg operations may also be found here, sometimes in AM mode (especially in Eastern Europe, Russia and the CIS countries/former Soviet Union) - with most activity centered roughly around 3.000 MHz (cf. 2910 kHz, 2920 kHz, etc. USB, and offset frequencies like 3005 kHz 3.005 MHz, 3017 kHz 3.017 MHz, 3020 kHz 3033 kHz 3.034 MHz etc.
USA Fishermen
- 8396 kHz USB last logged 1 Feb 2023.
- 8393.3 kHz USB last logged 2 Feb 2023.
- 8296 kHz USB last logged 30 Dec 2022.
- 7654 kHz USB
- 6969 kHz USB
- 6959 kHz USB Mentions of New Bedford, last logged 18 Feb 2023.
- 6319.5 kHz USB last logged 2 Feb 2023.
- 6282 kHz USB last logged 19 Jan 2023.
- 6263.5 kHz USB last logged 29 Dec 2022.
- 6144.5 kHz USB last logged 29 Jan 2023.
- 6095 kHz USB
- 6090 kHz USB
- 5665 kHz USB
- 4876.5 kHz USB last logged 1 Feb 2023.
- 4508 kHz USB Perhaps CT/Long Island area, last logged 19 Dec 2022.
- 4378 kHz USB they also use 8296, last logged 30 Dec 2022.
- 4321 kHz USB - U.S. East Coast
- 4009 kHz USB Mentions of New Bedford, last logged 19 Feb 2023.
- Return to List of Pirate Radio Frequencies
