HF airband
HF aeronautical bands. The 3800-3950 kHz range is generally not used in ITU Region 2 and is shared with other services. 3 kHz frequency steps (channelization), USB voice used with SELCAL extensively used. Military generally uses 3 kHz steps but will sometimes use split or offset frequencies and non-voice modes.
See the MWARA page for specific frequencies, including VOLMET broadcasts (meteo) transmissions, weather frequencies and HF long-range ATC frequencies. Additional resources include:
- New York Radio
- Aircraft SELCALL (Selective Calling system used over HF radio voice circuits)
- VOR
- ILS
- DME
- Non directional beacon or NDB
This page is for the bands only.
Note: these bands are often shared with other allocated users, especially maritime mobile service (SSB marine) and are heavily pirated (bootlegged) by the “peskies”. Overlapping allocations also into the 75m ham radio and shortwave broadcasting bands.
See also MF/HF marine bands, MF/HF fixed/mobile bands and the VHF aircraft band (airband)
MF SSB and HF SSB aircraft bands
| Frequency Range | civil sub band / military sub band |
| 2850 kHz to 3155 kHz | 2850 - 3025 kHz civilian / 3025 - 3155 kHz military |
| 3400 kHz to 3500 kHz | 3400 - 3500 kHz civilian |
| 3800 kHz to 3950 kHz | 3800 - 3950 kHz civilian (shared with 75 meter amateur band and 75 meter shortwave broadcast)) |
| 4650 kHz to 4750 kHz | 4650 - 4700 kHz civilian / 4700 - 4750 kHz military |
| 5450 kHz to 5730 kHz | 5450 - 5680 kHz civilian / 5680 - 5730 kHz military |
| 6525 kHz to 6765 kHz | 6525 - 6685 kHz civilian / 6685 - 6765 kHz military |
| 8815 kHz to 9040 kHz | 8815 - 8965 kHz civilian / 8965 - 9040 kHz military |
| 10005 kHz to 10100 kHz | 10005 - 10100 kHz civilian |
| 11175 kHz to 11400 kHz | 11175 - 11275 military / 11275 - 11400 kHz military |
| 13200 kHz to 13360 kHz | 13200 - 13260 civilian / 13260 - 13360 kHz military |
| 15010 kHz to 15100 kHz | 15010 - 15100 kHz military |
| 17900 kHz to 18030 kHz | 17900 - 17970 civilian / 17970 - 18030 kHz military |
| 21870 kHz to 22000 kHz | 21870 - 22000 kHz civilian |
| 23200 kHz to 23350 kHz | 23200 - 23350 kHz civilian |
Notes:
- The 3400 kHz - 3500 kHz band and 6525 kHz - 6685 kHz band are both heavily used by unlicensed stations, the peskies. The 6,525 kHz to 6,765 kHz band is extensively pirated by stations operating under the so-called Echo Charlie or EC band or 45 meter band.
