HF marine
See also: VHF marine band
| Band | Frequency Range |
| 2450-2850 kHz | MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-4 MHz AM mode, many users operate outside this band, roughly around 3 MHz) |
| 16360-17460 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 25070-25121 kHz | HF 25 MHz marine band - the 25 MHz and 26 MHz bands are shared with land mobile and fixed/mobile services |
| 26145-26175 kHz | HF 26 MHz marine band - shared with fixed and mobile services, including ocean-based telemetry systems and land mobile services |
| 26175-30000 kHz | Various CB-like marine allocations found in this region (some SSB marine radios stop at 27500 kHz or 27.500 MHz instead of 29.999 MHz) |
DSC should not be confused with DCS, digital coded squelch, a selective calling squelch system used on VHF/UHF land mobile radio systems.
- 2182 kHz Voice - no longer monitored by USCG, still monitored by private and commercial vessels and shore stations worldwide
- 2187.5 kHz DSC
- 4125 kHz Voice SSB
- 4207.5 kHz DSC
- 6215 kHz Voice
- 6312 kHz DSC
- 8291 kHz Voice
- 8414 kHz DSC
- 12290 kHz Voice
- 12577 kHz DSC
- 16420 kHz Voice
- 16804.5 kHz DSC
- 3023 kHz USB - Voice SAR on-scene coordination / communications - Civil / Military - Night Scene of Search SAMAR 1
- 3085 kHz USB - Voice SAR on-scene coordination / communications - Military - Night Scene of Search SAMAR 4
- 5680 kHz USB - Voice SAR on-scene coordination / communications - Civil / Military - Day Scene of Search SAMAR 1
- 5695 kHz USB - Voice SAR on-scene coordination / communications - Military - Day Scene of Search SAMAR 4
- 8364 kHz USB - Voice SAR on-scene coordination / communications
- 10003 kHz USB - Voice SAR on-scene coordination / communications
- 14993 kHz USB - Voice SAR on-scene coordination / communications
SSB Sailing Net Frequencies
- 6215 kHz USB - Caribbean Net 10:00 UTC - 12:00 UTC
- 4045 kHz USB - Caribbean Weather Center Net 10:40 UTC
- 8137 kHz USB - Caribbean Weather Center Net 10:40 UTC
- 4036 kHz USB - Ocean Cruising Club Net Primary 11:00 UTC - July - mid September
- 6227 kHz USB - Ocean Cruising Club Net Secondary 11:00 UTC - July - mid September
- 8137 kHz USB - Caribbean Weather Center Net 11:30 UTC
- 12350 kHz USB - Caribbean Weather Center Net 11:30 UTC
- 8170 kHz USB - Coconut Telegraph Net Primary 12:00 UTC
- 8146 kHz USB - Coconut Telegraph Net Secondary 12:00 UTC
- 8164 kHz USB - Coconut Telegraph Net Alternate 12:00 UTC
- 8104 kHz USB - Seven Seas Cruising Association SSCA Net - "KPA" - 12:15 UTC
- 8170 kHz USB - Cruiseheimers Net Primary 12:30 UTC
- 8146 kHz USB - Cruiseheimers Net Secondary 12:30 UTC
- 8164 kHz USB - Cruiseheimers Net Secondary 12:30 UTC
- 8137 kHz USB - Caribbean Weather Center Net 12:30 UTC
- 12350 kHz USB - Caribbean Weather Center Net 12:30 UTC
- 6209 kHz USB - Southwest Caribbean Net SW Caribbean Net Primary 13:15 UTC
- 6212 kHz USB - Southwest Caribbean Net SW Caribbean Net Secondary 13:15 UTC
- 6516 kHz USB - Southwest Caribbean Net SW Caribbean Net Secondary 13:15 UTC
- 2582 kHz USB - Bermuda Harbor Control Net 13:30 UTC
- 8107 kHz USB - Panama Connection Net Primary 13:30 UTC
- 8167 kHz USB - Panama Connection Net Secondary 13:30 UTC
- 6209 kHz USB - Northwest Caribbean Net NW Caribbean Net Primary 14:00 UTC
- 6212 kHz USB - Northwest Caribbean Net NW Caribbean Net Secondary 14:00 UTC
- 6516 kHz USB - Northwest Caribbean Net NW Caribbean Net Secondary 14:00 UTC
Designated Simplex SSB Radiotelephone Voice Frequencies
U.S. designated frequencies in the 2 MHz - 30 MHz band are listed below. Many of these are shared with other services and may be assigned for other marine purposes per ITU rules (see below).
These frequencies are designated for radiotelephone operations (voice, USB mode, frequency indicated is the dial frequency, in other words, 2003.0 kHz is what your radio's display should show for operating on 2003 kHz). Emission J3E is the primary emission on these frequencies. DSC may be used, in which case, emission must be J2B. USB voice emission is 2.8 kHz bandwidth, emission designator 2K80J3E. R3E may be used on distress, safety and calling frequencies, in which case the emission designator is 2K80R3E.
- 2003.0 kHz - Ship to ship and ship to shore, private communications - Great Lakes only
- 2065.0 kHz - Business and operational communications
- 2079.0 kHz - Business and operational communications
- 2082.5 kHz - Ship to ship and ship to shore, private communications - All areas
- 2086.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 2093.0 kHz - Ship to ship and ship to shore, private communications - All areas
- 2096.5 kHz - Business and operational communications
- 2142.0 kHz - Ship to ship and ship to shore, private communications - Pacific coast areas south of 42 degrees North - daytime only
- 2203.0 kHz - Ship to ship and ship to shore, private communications - Gulf of Mexico
- 2214.0 kHz - Ship to ship and ship to shore, private communications - All areas
- 2638.0 kHz - Ship to ship and ship to shore, private communications - All areas, navigational information
- 2670.0 kHz - Ship to ship and ship to shore, private communications - All areas
- 2738.0 kHz - Ship to ship and ship to shore, private communications - All areas except the Great Lakes, navigational information
- 2782.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 2830.0 kHz - Ship to ship and ship to shore, private communications - Gulf of Mexico
- 3023.0 kHz - Scene of action Search and Rescue (SAR) communications only
- 4065.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 4089.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 4116.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 4146.0 kHz - Business and operational communications
- 4149.0 kHz - Business and operational communications
- 4408.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 4417.0 kHz - Calling and reply use and Business and operational communications
- 5680.0 kHz - Scene of action Search and Rescue (SAR) communications only
- 6209.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 6212.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 6224.0 kHz - Business and operational communications
- 6227.0 kHz - Business and operational communications
- 6230.0 kHz - Business and operational communications
- 6510.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 6513.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 6516.0 kHz - Calling and reply use and business and operational communications - daytime only
- 8201.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 8213.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 8725.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 8737.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 8294.0 kHz - Business and operational communications
- 8297.0 kHz - Business and operational communications
- 12353.0 kHz - Business and operational communications
- 12356.0 kHz - Business and operational communications
- 12359.0 kHz - Business and operational communications
- 12362.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 12365.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 16528.0 kHz - Business and operational communications
- 16531.0 kHz - Business and operational communications
- 16534.0 kHz - Business and operational communications
- 16537.0 kHz - Public Correspondence simplex ship-to-shore
- 16540.0 kHz - Public Correspondence simplex ship-to-shore
- 16543.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 16546.0 kHz - Mississippi River System working - ship to ship and ship to shore
- 18825.0 kHz - Public Correspondence simplex ship-to-shore
- 18828.0 kHz - Public Correspondence simplex ship-to-shore
- 18831.0 kHz - Public Correspondence simplex ship-to-shore
- 18834.0 kHz - Public Correspondence simplex ship-to-shore
- 18837.0 kHz - Public Correspondence simplex ship-to-shore
- 18840.0 kHz - Business and operational communications
- 18843.0 kHz - Business and operational communications
- 22159.0 kHz - Business and operational communications
- 22162.0 kHz - Business and operational communications
- 22165.0 kHz - Business and operational communications
- 22168.0 kHz - Business and operational communications
- 22171.0 kHz - Business and operational communications
- 22174.0 kHz - Public Correspondence simplex ship-to-shore
- 22177.0 kHz - Public Correspondence simplex ship-to-shore
- 25100.0 kHz - Public Correspondence simplex ship-to-shore
- 25103.0 kHz - Public Correspondence simplex ship-to-shore
- 25106.0 kHz - Public Correspondence simplex ship-to-shore
- 25109.0 kHz - Public Correspondence simplex ship-to-shore
- 25112.0 kHz - Public Correspondence simplex ship-to-shore
- 25115.0 kHz - Business and operational communications
- 25118.0 kHz - Business and operational communications
- 2003.0 kHz
- 2065.0 kHz
- 2079.0 kHz
- 2082.5 kHz
- 2086.0 kHz
- 2093.0 kHz
- 2096.5 kHz
- 2142.0 kHz
- 2203.0 kHz
- 2214.0 kHz
- 2635.0 kHz
- 2638.0 kHz
- 2738.0 kHz
- 2782.0 kHz
- 2830.0 kHz
- 4146.0 kHz
- 4149.0 kHz
- 4417.0 kHz
- 6224.0 kHz
- 6227.0 kHz
- 6230.0 kHz
- 6516.0 kHz
- 8294.0 kHz - Channel 8A / Channel A
- 8297.0 kHz - Channel 8B / Channel B
- 12353.0 kHz
- 12356.0 kHz
- 12359.0 kHz
- 12362.0 kHz
- 12365.0 kHz
- 16528.0 kHz
- 16531.0 kHz
- 16534.0 kHz
- 16537.0 kHz
- 16540.0 kHz
- 16543.0 kHz
- 16546.0 kHz
- 18825.0 kHz
- 18828.0 kHz
- 18831.0 kHz
- 18834.0 kHz
- 18837.0 kHz
- 18840.0 kHz
- 18843.0 kHz
- 22159.0 kHz
- 22162.0 kHz
- 22165.0 kHz
- 22168.0 kHz
- 22171.0 kHz
- 22174.0 kHz
- 22177.0 kHz
- 25100.0 kHz - Channel 25A
- 25103.0 kHz - Channel 25B
- 25106.0 kHz - Channel 25C
- 25109.0 kHz - Channel 25D
- 25112.0 kHz - Channel 25E
- 25115.0 kHz - Channel 25F
- 25118.0 kHz - Channel 25G
Simplex Frequencies - Additional
These frequencies are used for ship to ship communications and are shared with fixed/mobile services worldwide. Due to the nature of the HF spectrum allocation system, the shared frequencies are only available on the 4 MHz and 8 MHz bands
- 4 MHz band - 4000 kHz - 4060 kHz, 3 kHz spacing, USB voice
- 4000.0 kHz
- 4003.0 kHz
- 4006.0 kHz
- 4009.0 kHz
- 4012.0 kHz
- 4015.0 kHz
- 4018.0 kHz
- 4021.0 kHz
- 4024.0 kHz
- 4027.0 kHz
- 4030.0 kHz
- 4033.0 kHz
- 4036.0 kHz
- 4039.0 kHz
- 4042.0 kHz
- 4045.0 kHz
- 4048.0 kHz
- 4051.0 kHz
- 4054.0 kHz
- 4057.0 kHz
- 4057.0 kHz
- 4060.0 kHz
- 8 MHz band - 8101 kHz to 8191 kHz 3 kHz spacing, USB voice
The 7450 kHz to 8100 kHz portion of the fixed/mobile band is not included in this shared spectrum...however, many marine users use these frequencies anyway, especially the lower portion of the 8 MHz band and the higher portion of the 7 MHz band.
- 8101.0 kHz
- 8104.0 kHz
- 8107.0 kHz
- 8110.0 kHz
- 8113.0 kHz
- 8116.0 kHz
- 8119.0 kHz
- 8122.0 kHz
- 8125.0 kHz
- 8128.0 kHz
- 8131.0 kHz
- 8134.0 kHz
- 8137.0 kHz
- 8140.0 kHz
- 8143.0 kHz
- 8146.0 kHz
- 8149.0 kHz
- 8152.0 kHz
- 8155.0 kHz
- 8158.0 kHz
- 8161.0 kHz
- 8164.0 kHz
- 8167.0 kHz
- 8170.0 kHz
- 8173.0 kHz
- 8176.0 kHz
- 8179.0 kHz
- 8182.0 kHz
- 8185.0 kHz
- 8188.0 kHz
- 8191.0 kHz
These frequencies are specifically designated for duplex use (generally ship-to-shore or shore-to-ship comms). Simplex operations are very common, often using the ship frequency, but simplex ship to ship comms are found on the shore frequencies as well.
| ITU Channel | Ship Transmit / Coast Receive | Coast Transmit / Ship Receive |
| 401 | 4065 kHz | 4357 kHz |
| 402 | 4068 kHz | 4360 kHz |
| 403 | 4071 kHz | 4363 kHz |
| 404 | 4074 kHz | 4366 kHz |
| 405 | 4077 kHz | 4369 kHz |
| 406 | 4080 kHz | 4372 kHz |
| 407 | 4083 kHz | 4375 kHz |
| 408 | 4086 kHz | 4378 kHz |
| 409 | 4089 kHz | 4381 kHz |
| 410 | 4092 kHz | 4384 kHz |
| 411 | 4095 kHz | 4387 kHz |
| 412 | 4098 kHz | 4390 kHz |
| 413 | 4101 kHz | 4393 kHz |
| 414 | 4104 kHz | 4396 kHz |
| 415 | 4107 kHz | 4399 kHz |
| 416 | 4110 kHz | 4402 kHz |
| 417 | 4113 kHz | 4405 kHz |
| 418 | 4116 kHz | 4408 kHz |
| 419 | 4119 kHz | 4411 kHz |
| 420 | 4122 kHz | 4414 kHz |
| 421 | 4125 kHz | 4417 kHz |
| 422 | 4128 kHz | 4420 kHz |
| 423 | 4131 kHz | 4423 kHz |
| 424 | 4134 kHz | 4426 kHz |
| 425 | 4137 kHz | 4429 kHz |
| 426 | 4140 kHz | 4432 kHz |
| 427 | 4143 kHz | 4435 kHz |
| 601 | 6200 kHz | 6501 kHz |
| 602 | 6203 kHz | 6504 kHz |
| 603 | 6206 kHz | 6507 kHz |
| 604 | 6209 kHz | 6510 kHz |
| 605 | 6212 kHz | 6513 kHz |
| 606 | 6215 kHz | 6516 kHz |
| 607 | 6218 kHz | 6519 kHz |
| 608 | 6221 kHz | 6522 kHz |
| 801 | 8195 kHz | 8719 kHz |
| 802 | 8198 kHz | 8722 kHz |
| 803 | 8201 kHz | 8725 kHz |
| 804 | 8204 kHz | 8728 kHz |
| 805 | 8207 kHz | 8731 kHz |
| 806 | 8210 kHz | 8734 kHz |
| 807 | 8213 kHz | 8737 kHz |
| 808 | 8216 kHz | 8740 kHz |
| 809 | 8219 kHz | 8743 kHz |
| 810 | 8222 kHz | 8746 kHz |
| 811 | 8225 kHz | 8749 kHz |
| 812 | 8228 kHz | 8752 kHz |
| 813 | 8231 kHz | 8755 kHz |
| 814 | 8234 kHz | 8758 kHz |
| 815 | 8237 kHz | 8761 kHz |
| 816 | 8240 kHz | 8764 kHz |
| 817 | 8243 kHz | 8767 kHz |
| 818 | 8246 kHz | 8770 kHz |
| 819 | 8249 kHz | 8773 kHz |
| 820 | 8252 kHz | 8776 kHz |
| 821 | 8255 kHz | 8779 kHz |
| 822 | 8258 kHz | 8782 kHz |
| 823 | 8261 kHz | 8785 kHz |
| 824 | 8264 kHz | 8788 kHz |
| 825 | 8267 kHz | 8791 kHz |
| 826 | 8270 kHz | 8794 kHz |
| 827 | 8273 kHz | 8797 kHz |
| 828 | 8276 kHz | 8800 kHz |
| 829 | 8279 kHz | 8803 kHz |
| 830 | 8282 kHz | 8806 kHz |
| 831 | 8285 kHz | 8809 kHz |
| 832 | 8288 kHz | 8812 kHz |
| 1201 | 12230 kHz | 13077 kHz |
| 1202 | 12233 kHz | 13080 kHz |
| 1203 | 12236 kHz | 13083 kHz |
| 1204 | 12239 kHz | 13086 kHz |
| 1205 | 12242 kHz | 13089 kHz |
| 1206 | 12245 kHz | 13092 kHz |
| 1207 | 12248 kHz | 13095 kHz |
| 1208 | 12251 kHz | 13098 kHz |
| 1209 | 12254 kHz | 13101 kHz |
| 1210 | 12257 kHz | 13104 kHz |
| 1211 | 12260 kHz | 13107 kHz |
| 1212 | 12263 kHz | 13110 kHz |
| 1213 | 12266 kHz | 13113 kHz |
| 1214 | 12269 kHz | 13116 kHz |
| 1215 | 12272 kHz | 13119 kHz |
| 1216 | 12275 kHz | 13122 kHz |
| 1217 | 12278 kHz | 13125 kHz |
| 1218 | 12281 kHz | 13128 kHz |
| 1219 | 12284 kHz | 13131 kHz |
| 1220 | 12287 kHz | 13134 kHz |
| 1221 | 12290 kHz | 13137 kHz |
| 1222 | 12293 kHz | 13140 kHz |
| 1223 | 12296 kHz | 13143 kHz |
| 1224 | 12299 kHz | 13146 kHz |
| 1225 | 12302 kHz | 13149 kHz |
| 1226 | 12305 kHz | 13152 kHz |
| 1227 | 12308 kHz | 13155 kHz |
| 1228 | 12311 kHz | 13158 kHz |
| 1229 | 12314 kHz | 13161 kHz |
| 1230 | 12317 kHz | 13164 kHz |
| 1231 | 12320 kHz | 13167 kHz |
| 1232 | 12323 kHz | 13170 kHz |
| 1233 | 12326 kHz | 13173 kHz |
| 1234 | 12329 kHz | 13176 kHz |
| 1235 | 12332 kHz | 13179 kHz |
| 1236 | 12335 kHz | 13182 kHz |
| 1237 | 12338 kHz | 13185 kHz |
| 1238 | 12341 kHz | 13188 kHz |
| 1239 | 12344 kHz | 13191 kHz |
| 1240 | 12347 kHz | 13194 kHz |
| 1241 | 12347 kHz | 13197 kHz |
| 1601 | 16360 kHz | 17242 kHz |
| 1602 | 16363 kHz | 17245 kHz |
| 1603 | 16366 kHz | 17248 kHz |
| 1604 | 16369 kHz | 17251 kHz |
| 1605 | 16372 kHz | 17254 kHz |
| 1606 | 16375 kHz | 17257 kHz |
| 1607 | 16378 kHz | 17260 kHz |
| 1608 | 16381 kHz | 17263 kHz |
| 1609 | 16384 kHz | 17266 kHz |
| 1610 | 16387 kHz | 17269 kHz |
| 1611 | 16390 kHz | 17272 kHz |
| 1612 | 16393 kHz | 17275 kHz |
| 1613 | 16396 kHz | 17278 kHz |
| 1614 | 16399 kHz | 17281 kHz |
| 1615 | 16402 kHz | 17284 kHz |
| 1616 | 16405 kHz | 17287 kHz |
| 1617 | 16408 kHz | 17290 kHz |
| 1618 | 16411 kHz | 17293 kHz |
| 1619 | 16414 kHz | 17296 kHz |
| 1620 | 16417 kHz | 17299 kHz |
| 1621 | 16420 kHz | 17302 kHz |
| 1622 | 16423 kHz | 17305 kHz |
| 1623 | 16426 kHz | 17308 kHz |
| 1624 | 16429 kHz | 17311 kHz |
| 1625 | 16432 kHz | 17314 kHz |
| 1626 | 16435 kHz | 17317 kHz |
| 1627 | 16438 kHz | 17320 kHz |
| 1628 | 16441 kHz | 17323 kHz |
| 1629 | 16444 kHz | 17326 kHz |
| 1630 | 16447 kHz | 17329 kHz |
| 1631 | 16450 kHz | 17332 kHz |
| 1632 | 16453 kHz | 17335 kHz |
| 1633 | 16456 kHz | 17338 kHz |
| 1634 | 16459 kHz | 17341 kHz |
| 1635 | 16462 kHz | 17344 kHz |
| 1636 | 16465 kHz | 17347 kHz |
| 1637 | 16468 kHz | 17350 kHz |
| 1638 | 16471 kHz | 17353 kHz |
| 1639 | 16474 kHz | 17356 kHz |
| 1640 | 16477 kHz | 17359 kHz |
| 1641 | 16480 kHz | 17362 kHz |
| 1642 | 16483 kHz | 17365 kHz |
| 1643 | 16486 kHz | 17368 kHz |
| 1644 | 16489 kHz | 17371 kHz |
| 1645 | 16492 kHz | 17374 kHz |
| 1646 | 16495 kHz | 17377 kHz |
| 1647 | 16498 kHz | 17380 kHz |
| 1648 | 16501 kHz | 17383 kHz |
| 1649 | 16504 kHz | 17386 kHz |
| 1650 | 16507 kHz | 17389 kHz |
| 1651 | 16510 kHz | 17392 kHz |
| 1652 | 16513 kHz | 17395 kHz |
| 1653 | 16516 kHz | 17398 kHz |
| 1654 | 16519 kHz | 17401 kHz |
| 1655 | 16522 kHz | 17404 kHz |
| 1656 | 16525 kHz | 17407 kHz |
| 1801 | 18780 kHz | 19755 kHz |
| 1802 | 18783 kHz | 19758 kHz |
| 1803 | 18786 kHz | 19761 kHz |
| 1804 | 18789 kHz | 19764 kHz |
| 1805 | 18792 kHz | 19767 kHz |
| 1806 | 18795 kHz | 19770 kHz |
| 1807 | 18798 kHz | 19773 kHz |
| 1808 | 18801 kHz | 19776 kHz |
| 1809 | 18804 kHz | 19779 kHz |
| 1810 | 18807 kHz | 19782 kHz |
| 1811 | 18810 kHz | 19785 kHz |
| 1812 | 18813 kHz | 19788 kHz |
| 1813 | 18816 kHz | 19791 kHz |
| 1814 | 18819 kHz | 19794 kHz |
| 1815 | 18822 kHz | 19797 kHz |
| 2201 | 22000 kHz | 22696 kHz |
| 2202 | 22003 kHz | 22699 kHz |
| 2203 | 22006 kHz | 22702 kHz |
| 2204 | 22009 kHz | 22705 kHz |
| 2205 | 22012 kHz | 22708 kHz |
| 2206 | 22015 kHz | 22711 kHz |
| 2207 | 22018 kHz | 22714 kHz |
| 2208 | 22021 kHz | 22717 kHz |
| 2209 | 22024 kHz | 22720 kHz |
| 2210 | 22027 kHz | 22723 kHz |
| 2211 | 22030 kHz | 22726 kHz |
| 2212 | 22033 kHz | 22729 kHz |
| 2213 | 22036 kHz | 22732 kHz |
| 2214 | 22039 kHz | 22735 kHz |
| 2215 | 22042 kHz | 22738 kHz |
| 2216 | 22045 kHz | 22741 kHz |
| 2217 | 22048 kHz | 22744 kHz |
| 2218 | 22051 kHz | 22747 kHz |
| 2219 | 22054 kHz | 22750 kHz |
| 2220 | 22057 kHz | 22753 kHz |
| 2221 | 22060 kHz | 22756 kHz |
| 2222 | 22063 kHz | 22759 kHz |
| 2223 | 22066 kHz | 22762 kHz |
| 2224 | 22069 kHz | 22765 kHz |
| 2225 | 22072 kHz | 22768 kHz |
| 2226 | 22075 kHz | 22771 kHz |
| 2227 | 22078 kHz | 22774 kHz |
| 2228 | 22081 kHz | 22777 kHz |
| 2229 | 22084 kHz | 22780 kHz |
| 2230 | 22087 kHz | 22783 kHz |
| 2231 | 22090 kHz | 22786 kHz |
| 2232 | 22093 kHz | 22789 kHz |
| 2233 | 22096 kHz | 22792 kHz |
| 2234 | 22099 kHz | 22795 kHz |
| 2235 | 22102 kHz | 22798 kHz |
| 2236 | 22105 kHz | 22801 kHz |
| 2237 | 22108 kHz | 22804 kHz |
| 2238 | 22111 kHz | 22807 kHz |
| 2239 | 22114 kHz | 22810 kHz |
| 2240 | 22117 kHz | 22813 kHz |
| 2241 | 22120 kHz | 22816 kHz |
| 2242 | 22123 kHz | 22819 kHz |
| 2243 | 22126 kHz | 22822 kHz |
| 2244 | 22129 kHz | 22825 kHz |
| 2245 | 22132 kHz | 22828 kHz |
| 2246 | 22135 kHz | 22831 kHz |
| 2247 | 22138 kHz | 22834 kHz |
| 2248 | 22141 kHz | 22837 kHz |
| 2249 | 22144 kHz | 22840 kHz |
| 2250 | 22147 kHz | 22843 kHz |
| 2251 | 22150 kHz | 22846 kHz |
| 2252 | 22153 kHz | 22849 kHz |
| 2253 | 22156 kHz | 22852 kHz |
| 2501 | 25070 kHz | 26145 kHz |
| 2502 | 25073 kHz | 26148 kHz |
| 2503 | 25076 kHz | 26151 kHz |
| 2504 | 25079 kHz | 26154 kHz |
| 2505 | 25082 kHz | 26157 kHz |
| 2506 | 25085 kHz | 26160 kHz |
| 2507 | 25088 kHz | 26163 kHz |
| 2508 | 25091 kHz | 26166 kHz |
| 2509 | 25094 kHz | 26169 kHz |
| 2510 | 25097 kHz | 26172 kHz |
See also:
- VHF marine band
- Maritime Fax Transmissions
- Land Mobile Allocations 25 MHz - 30 MHz
- Chinese 480 channel / 960 channel HF/VHF low band 480 Channel / 960 channel FM fishery radiotelephone 27.500 MHz - 39.475 MHz
- Thai 10 watt / 25 watt AM FM SSB fishery marine CB radiocommunications service 168 channel 26 MHz 27 MHz
- Japanese 1 watt DSB (AM) double side band fishery radio service Japan 26-27 MHz 1W DSB 27MHz
- Japanese 25 watt SSB single side band fishery radio service Japan 27 MHz 25W SSB 27MHz
- Japanese 5 watt DSB (AM) double side band fishery radio service Japan 35.5 MHz-36 MHz and 39-40 MHz 5W DSB 40MHz
