Ionosonde
An ionosonde (or chirpsounder) is a specialized radar system for the examination of the ionosphere.
Description
An ionosonde consists of:
An ionosonde is used for finding the optimum operation frequencies for broadcasts or two-way communications in the high frequency range.
