Ionosonde
Revision as of 07:30, 6 September 2010 by Strange Attractor (Talk | contribs)
An IRX-58-23 ionosonde system.
Description
An ionosonde consists of:
  • A high frequency (HF) transmitter, automatically tunable over a wide range. Typically the frequency coverage is 0.5–23 MHz or 1–40 MHz, though normally sweeps are confined to approximately 1.6–12 MHz.
  • A tracking HF receiver which can automatically track the frequency of the transmitter.
  • An antenna with a suitable radiation pattern, which transmits well vertically upwards and is efficient over the whole frequency range used.
  • Digital control and data analysis circuits.
The transmitter sweeps all or part of the HF frequency range, transmitting short pulses. These pulses are reflected at various layers of the ionosphere, at heights of 100–400 km, and their echos are received by the receiver and analyzed by the control system. The result is displayed in the form of an ionogram.
Ionogram
The maximum usable frequency (MUF) for radio waves transmitted at a low angle over the horizon is approximate 3 times the highest frequency returned to the ionosonde from radio waves transmitted directly upwards (to the zenith of the location). Therefore, in the example above, where fxI was measured as 6.3 MHz, the MUF for ionospheric reflection at the area of the ionosonde was calculated as 18.7 MHz.
  1. F.C. Judd, "G2BCX Radio Wave Propagation (HF Bands)", Heinemann, London, ISBN 0-434-90926-2, 1987, pages 12–20,27–37
Wikipedia article: {{{1}}}
WP
