Revision as of 02:19, 24 April 2017 by R4002 (Talk | contribs)
Pirate shortwave broadcasts tend to be on well-known frequencies. This allows listeners to quickly find a pirate station when it comes on the air, as they only have a relatively few number of fixed places to look. Some of the locations on the HF band that are in frequent use as of September 2007 include: (Updated April 2017)
15070 active in the early 1990's by Europirates and pirates in North America, but recently quiet due to the solar cycle low
7415 historically, an extremely active frequency, more recently occupied by WBCQ
3375 AM/USB - used by Amphetamine Radio
3425 AM - used by The Crystal Ship (also reported on 3430)
3465 AM - reported used in 2017
4020 AM/USB
4025 AM/USB
4065 AM/USB
4085 AM/USB
5150 AM - used by Relay Station
5200 AM - used by Relay Station
6150 AM - used by European Pirates
6220 Used by Mystery Radio in Europe
6770 AM - used by Old Time Radio
6850 usually AM
6855 usually AM
6875 usually AM - noted use by The Crystal Ship (often 6876 kHz or similar close frequencies)
6880 usually AM - noted use by Unknown Name Radio Network
6888 usually AM - noted use by Unknown Name Radio Network
6900 usually AM, although 6900 LSB and 6900 USB are both heavily used by Spanish-speaking "peskies"
6915 AM/USB, 6912 kHz and 6912.5 kHz have also been noted as "split" frequencies between 6900 kHz and 6925 kHz
6923 USB - noted use by Amphetamine Radio
6925 most common frequency - virtually all modes have been heard
6930 AM/USB
6935 AM/USB
6940 AM/USB
6945 AM/USB
6950 AM/USB
6955 AM/USB
6960 AM/USB
6969 LSB - Used by Cold Country Canada
6970 AM - often used by XFM (also heard on 6975)
6975 AM - often used by XFM (also heard on 6970)
The 6765-7000 kHz band (referred to as "43 meters") is by far the most popular band for shortwave pirate radio. This band is internationally allocated to the fixed/mobile service and as a result many other legal (and illegal) voice and data users appear on these frequencies.
6925 kHz is the most used frequency at this time; however, it's important to note that the list will change. Broadcasters will experiment with new frequencies according to the season, and the appearance of utility, military, and broadcast stations on a favorite spot may also force stations to move to new locations.
The 43 meter band (6765-7000 kHz) is where most US-based pirates are found, generally clustered around 6925 kHz. Pirates tend to use 5 kHz steps up to 6975 kHz. The 43 meter band is also heavily used by so-called "peskies" (a play on the Spanish term "pescadores - meaning "fishermen"), stations engaging in two-way radio chatter in Portuguese, Spanish and other languages (including English). Peskies generally use LSB mode. 6925 kHz LSB is one of the most active peskie frequencies, which can cause serious interference issues for pirates operating in AM mode on 6925 kHz or adjacent frequencies. The area around 6900 kHz (including 6895 kHz and 6905 kHz) are also heavily used by Spanish-speaking stations in both USB and LSB modes. Unknown Name Radio Network has recently started using 6900 despite heavy QRM from SSB traffic on or near 6900 kHz.
A good place to look to get an idea of what frequencies are in current use is the FRN Loggings section or the HF Underground Shortwave Pirate logging section. and some stations will also announce a broadcast ahead of time on the FRN PX Announcements section.
Euro-Pirate Radio Frequencies
  • 3920-3950
  • 6200-6300
  • 6250 - Used in the 1980s
