High Frequency Beacon
Description
| 1654.95 | PRV | Preveza, Greece | Op: SW6HMU, QSL via [email protected] (Source: ndblist). | April 15, 2012 |
| 2097 | A | Arizona | (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 [1] | June 30, 2012 |
| 3450 | OK | OK | (Source: HF Underground Forum [2]) (Youtube video) | January 5, 2012 |
| 4079.7 | TMPnnn | SW Arizona | The TEMPERATURE BEACON - Temperature in deg. F. - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt [3] | March 4, 2012 |
| | WV | | ||
| 4096 | ......_ | VA | 6 dots 1 dash | March 24, 2012 |
| 4096.25 | Dasher | Joshua Tree N.P. | 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie') [4] [5] | April 6, 2013 |
| 4096.6 | Dasher | Mojave Nat. Preserve | 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie') [6] | March 24, 2012 |
| 4102.3 | W... | s.e. California desert | The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the , it sends lots of dits; and no wind, no dits. | April 6, 2013 |
| 5499.13 | Dasher | WA | ||
| 6398.5 | Common and Precious 2 | Berlin, Germany | Grid powered. 25W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 6547.0 | PRV | Preveza, Greece | Op: SW6HMU, QSL via [email protected] (Source: UDXF). Also reported on 6852.1 | January 22, 2012 |
| 6816 | FU | N. America | Active June 2011, no further info. (Source: A*C*E [7], [8]) (MP3 audio recording) | January 20, 2012 |
| HA | N. America | Active July 2011, no further info. (Source: A*C*E [9], HF Underground Forum [10]) . Sometimes the frequency is reported as "6815 kHz USB". (MP3 audio recording) | July 9, 2011 | |
| 6852.1 | PRV | Preveza, Greece | 15 W Op: SW6HMU (Source: UDXF). (2) (3) Occasionally active with irregular schedule. QSLs via [email protected] Former website [11] closed. Reported also on 6547.0 and 1654.95 kHz | April 24, 2012 |
| 6900 | Beeper | 0.5 sec beeps approx 1/sec (Source: HF Underground Forum [12]) | October 12, 2011 | |
| 6947.1 | 13 dits and 1 dah | No further info (Source: HF Underground Forum [13]) | October 24, 2011 | |
| 6961 | TR | Mojave desert, CA | (Source: HF Underground Forum [14]) | October 23, 2011 |
| 7542 | 55555 | W Europe or NE USA | (Source: [15], N&O-173(5), UDXF) | March 1, 2012 |
| 8193.8 | (Source: HF Underground Forum [16]) | October 23, 2011 | ||
| 8211.7 | OR | |||
| 8350 | Dasher | North Carolina | (Source: HF Underground Forum [17]) | December 31, 2011 |
| 10236.7 | Dasher | FL | ||
| 10237.74 | Common and Precious | Berlin, Germany | Grid powered. 5W into a 1/2λ Dipole. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 11428 | CZ | ? | (Source: HF Underground Forum [18]) | January 3, 2012 |
| 6398.5 | Common and Precious 3 | Berlin, Germany | Grid powered. 7W into a 5/8λ Vertical. Operates 24/7. Sends SQL Cards on request. (Project Thread on HFU Board) | Jule 19, 2017 |
| 26598 | Dasher | SW US | ~1/2 second dash every 29-31 seconds. 24/7. |
- HiFER
