Revision as of 12:10, 21 February 2018 by ChrisSmolinski (Talk | contribs)
Pirate shortwave broadcasts tend to be on well-known frequencies. This allows listeners to quickly find a pirate station when it comes on the air, as they only have a relatively few number of fixed places to look. Some of the locations on the HF band that are in frequent use as of September 2007 include: (Updated August 2017)
15070 active in the early 1990's by Europirates and pirates in North America, but recently quiet due to the solar cycle low
7415 historically, an extremely active frequency, more recently occupied by WBCQ
1710 AM - Mediumwave pirates
1720 AM - Mediumwave pirates - known as the "AM pirate clear channel"
3375 AM/USB - used by Amphetamine Radio
3425 AM - used by The Crystal Ship (also reported on 3430)
3465 AM - reported used in 2017
4020 AM/USB
4025 AM/USB
4060 AM/USB
4065 AM/USB
4080 AM/USB
4085 AM/USB
5010 AM - used by Relay Station
5015 AM - used by Relay Station
5150 AM - used by Relay Station
5200 AM - used by Relay Station
6150 AM - used by European Pirates
6220 Used by Mystery Radio in Europe
6750 AM/SSB - reported in use August 2017
6770 AM - used by Old Time Radio and UNID stations
6780 AM - sporadically used by Old Time Radio
6850 usually AM
6855 usually AM
6875 usually AM - noted use by The Crystal Ship (often 6876 kHz or similar close frequencies)
6880 usually AM - noted use by Unknown Name Radio Network
6888 usually AM - noted use by Unknown Name Radio Network
6900 usually AM, although 6900 LSB and 6900 USB are both heavily used by Spanish-speaking "peskies"
6905 AM - noted use by Unknown Name Radio Network, another commonly use pescadore frequency in LSB mode
6915 AM/USB
6920 AM/USB
6923 USB - noted use by Amphetamine Radio
6925 most common frequency - virtually all modes have been heard
6930 AM/USB
6935 AM/USB
6940 AM/USB - noted use by Clever Name Radio
6945 AM/USB
6950 AM/USB
6955 AM/USB
6960 AM/USB
6969 LSB - Used by Cold Country Canada
6970 AM - often used by XFM (also heard on 6975)
6975 AM - often used by XFM (also heard on 6970)
6995 AM/SSB - recently (July 2017) used by KUNT
The 43 meter band (6765-7000 kHz) is where most US-based pirates are found, generally clustered around 6925 kHz. Because many pirates use older-generation transmitters, it is not uncommon to find stations on "6925" actually using 6924 kHz to 6926 kHz. AM transmissions operating in the 6925.5 kHz to 6925.9 kHz area are often logged Pirates tend to use 5 kHz steps up to 6975 kHz. However, use "split" or "offset" frequencies is also common, examples include 6912.5 kHz, 6969 kHz, 6929.5 kHz, etc. Offset frequencies (for example, 6876 kHz instead of 6875 kHz can sometimes be due to quirks of transmitting equipment).
Euro-Pirate Radio Frequencies
  • 3920-3950
  • 6200-6300
  • 6250 - Used in the 1980s
