Revision as of 14:43, 12 December 2018 by R4002 (Talk | contribs)
(Updated November 2018)
4020 kHz AM/USB
4025 kHz AM/USB
4060 kHz AM/USB
4065 kHz AM/USB
4080 kHz AM/USB
4085 kHz AM/USB
6770 kHz AM - used by Old Time Radio
6840 kHz AM
6850 kHz usually AM
6855 kHz usually AM
6870 kHz AM/USB
6885 kHz AM/USB
6886 kHz AM/USB - used by Mix Radio International in October 2018
6890 kHz AM/USB
6915 kHz AM/USB
6920 kHz AM/USB
6925 kHz most common frequency - virtually all modes have been heard +/- 1-2 kHz
6930 kHz AM/USB
6935 kHz AM/USB - Latin American pirates can also be heard here
6945 kHz AM/USB
6950 kHz AM/USB
6955 kHz AM/USB
6965 kHz AM/USB
6970 kHz AM
6975 kHz AM/USB - often used by XFM (also heard on 6970)
Euro-Pirate Radio Frequencies
  • 3920-3950 (75 meters)
  • 6250 - Used in the 1980s
