VHF airband
Military aircraft retain the capability to transmit and receive on the VHF-AM aircraft band, with US military aircraft radios covering up to 150 MHz in AM mode. Military aircraft also make extensive use of the UHF-AM aircraft band 225-400 MHz.
| Frequency | Purpose/Use |
| 121.500 MHz | Emergency Frequency known as Guard, see also 243.0 MHz - UHF Guard |
| 122.900 MHz | Common SAR (Search and Rescue) aircraft frequency) |
| 123.100 MHz | Common SAR (Search and Rescue) aircraft frequency) |
| 123.450 MHz | Unofficial air-to-air pilot chit-chat frequency |
| 123.475 MHz | Unofficial air-to-air pilot chit-chat frequency |
