SINCGARS
| Contents |
VHF-FM tactical radio system, with frequency-hopping and voice encryption/data encryption capabilities. Operating in the 30.000 to 87.975 MHz frequency band with 25 kHz channel steps. Uses 150.0 Hz CTCSS squelch system. Operates in single-channel (SC) and frequency-hopping (FH) modes for voice and data. Most radios include repeater capability (called RETRANS or retransmit in military usage). Compatible with previous-generation FM radios such as the PRC-25, PRC-77, PRC-1077, HH7700 and dozens of other similar tactical handheld, manpack and vehicle-mounted radios operating in the 30-76 MHz or 30-88 MHz range. NATO military forces and many other military forces use similar frequencies for tactical purposes, almost always with FM voice. The US military fields radios that operate in the 30-174 MHz and 30-512 MHz ranges to support SINCGARS, regular VHF-FM, 136-174 MHz VHF-high band services like VHF marine, aircraft radios, SATCOM and interoperability with other radio systems that use VHF/UHF.
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
It is important to note that in SC mode or single channel mode, SINCGARS radios allow for -5 kHz / +5 kHz or -10 kHz / +10 kHz offsets, effectively changing the 25 kHz frequency step to 5 kHz frequency step, allowing for use of non-standard frequencies in single-channel mode. In FH mode or frequency hopping mode channels are 25 kHz frequency steps.
Background and History
Because previous-generation, vintage or antique military radios with 30-76 MHz or 30-88 MHz frequency bands cover the 6 meter amateur band, and WWII and Korean War vintage equipment covers 20-28 MHz or 20-27.9 MHz and 27-38.9 MHz or 27-39 MHz amateur radio operators will often use surplus equipment in the 10 meter and 6 meter bands for FM communications. Vintage military radio equipment is also used by amateur operators in the HF bands and VHF bands above 6 meters where available. This includes the 4 meter band around 70 MHz, which is available in select countries for amateur use. The PRC-8, PRC-8A, PRC-9, PRC-9A, PRC-10, PRC-10A, PRC-25, PRC-77 and similar radios are very popular with amateur or ham radio operators who keep these vintage radios alive by operating them on the amateur bands. 51.0 MHz is the most common military amateur radio frequency on 6 meters.
