Revision as of 18:56, 25 January 2019 by R4002 (Talk | contribs)
VHF low band VHF-low
VHF high band VHF band
UHF band
800 MHz band
  • 27.9000 MHz - NATO Combat Scene of Action Common
  • 36.2500 MHz - Oil spill cleanup/interop
  • 40.5000 MHz - US Military SAR FM channel - CSQ or 150.0 Hz military CTCSS tone
  • 41.7100 MHz - Oil spill cleanup/interop
  • 47.8000 MHz - NATO Combat Scene of Action Common
UHF band
