Law enforcement, fire/EMS, medical and general public safety interoperability frequencies.  Most states, regions and even cities will have additional frequencies or dedicated talkgroups on their trunking systems.  Some areas include provisions to patch trunking systems to analog repeaters on the interop frequencies below.
| Contents |
VHF low band VHF-low
VHF high band VHF band
- 150.9800 MHz - Oil Spill Cleanup 1 (simplex or repeater input/output)
- 154.5850 MHz - Oil Spill Cleanup 2 (simplex or repeater input/output)
- 158.4450 MHz - Oil Spill Cleanup 3 (simplex or repeater input/output)
- 159.4800 MHz - Oil Spill Cleanup 4 (simplex or repeater input/output)
UHF band
800 MHz band
- 36.2500 MHz - Oil spill cleanup/interop
- 40.5000 MHz - US Military SAR FM channel - CSQ or 150.0 Hz military CTCSS tone
- 41.7100 MHz - Oil spill cleanup/interop
UHF band
