Revision as of 19:05, 25 January 2019 by R4002 (Talk | contribs)
VHF low band VHF-low
VHF high band VHF band
  • 150.9800 MHz - Oil spill cleanup interop (simplex or repeater input/output)
  • 154.5850 MHz - Oil spill cleanup interop (simplex or repeater input/output)
UHF band
  • 454.0000 MHz - Oil spill cleanup interop (simplex or repeater output, paired with 459.0 MHz)
  • 459.0000 MHz - Oil spill cleanup interop (simplex or repeater input, paired with 454.0 MHz)
800 MHz band
UHF band
