Revision as of 19:07, 25 January 2019 by R4002 (Talk | contribs)
VHF low band VHF-low
  • 36.2500 MHz - Oil spill cleanup/interop (simplex or repeater input/output, paired with 36.25 MHz)
  • 41.7100 MHz - Oil spill cleanup/interop (simplex or repeater input/output, paired with 41.71 MHz)
VHF high band VHF band
  • 150.9800 MHz - Oil spill cleanup interop (simplex or repeater input/output)
  • 154.5850 MHz - Oil spill cleanup interop (simplex or repeater input/output)
UHF band
  • 454.0000 MHz - Oil spill cleanup interop (simplex or repeater output, paired with 459.0 MHz)
  • 459.0000 MHz - Oil spill cleanup interop (simplex or repeater input, paired with 454.0 MHz)
800 MHz band
  • 40.5000 MHz - US Military SAR FM channel - CSQ or 150.0 Hz military CTCSS tone
UHF band
