VHF airband
Military aircraft retain the capability to transmit and receive on the VHF-AM aircraft band, with US military aircraft radios covering up to 150 MHz in AM mode. Military aircraft also make extensive use of the UHF-AM aircraft band 225-400 MHz, often with ECCM systems such as HAVE QUICK, HAVE QUICK II and SATURN frequency hopping modes. The 225-400 MHz band is also extensively used for SATCOM and other purposes outside the scope of air-to-air communications. 380-400 MHz is shared with land mobile radio systems used by the US military in the United States. Military aircraft in close air support, MEDEVAC and other roles will also be equipped with VHF-FM SINCGARS tactical military radios for air-to-ground and air-to-air communications in both frequency hopping (FH) and single-channel (SC) modes.
| Frequency | Purpose/Use |
| 121.500 MHz | Emergency Frequency known as Guard, see also 243.0 MHz - UHF Guard |
| 122.900 MHz | Secondary SAR (Search and Rescue) air-to-air/air-to-ground |
| 123.100 MHz | Primary SAR (Search and Rescue) air-to-air/air-to-ground, also used by Civil Air Patrol |
| 123.450 MHz | Unofficial air-to-air pilot chit-chat frequency |
| 123.475 MHz | Unofficial air-to-air pilot chit-chat frequency |
| 126.200 MHz | Common US military airfield VHF frequency (often as backup to UHF-AM and FM tactical radios) |
| 131.550 MHz | ACARS air-to-ground datalink frequency (North America) |
| 136.975 MHz | ACARS air-to-ground datalink frequency (North America) |
See also:
