Dead Hand System
220px-DUGA_Radar_Array_near_Chernobyl%2C_Ukraine_2014.jpg Sa-10c_b.jpg buck1sa11.jpg
(Image on left: Duga-1 Radar Array, near Chernobyl, Ukraine. Theorized by some to be a Dead Hand System)
(Image at center: S-300/SA-10 "Grumbler" surface-to-air missile launchers, theorized by some to be a Dead Hand command launcher)
(Image at right: 9M36 BUK-1/SA-17 "Gadfly" surface-to-air missile launcher, theorized by some to be a signal command system for Dead Hand)
System concept
Working principles
Upon activation and determination of the happening of a nuclear war, the system sends out a 15P011 command missile with a special 15B99 warhead which passes commands to open all silos and all command centers of the RVSN with appropriate receivers in flight. The command missile system is similar with the US Emergency Rocket Communications System.
Components
Commanding rocket:
Motivation
Operation
Current use
UVB-76 (The Buzzer)
Sources
All sources courtesy of Wikipedia, Military Today, the New York Times archive, and National Interest
