Dead Hand System
220px-DUGA_Radar_Array_near_Chernobyl%2C_Ukraine_2014.jpg 300px-%D0%A1-400_%C2%AB%D0%A2%D1%80%D0%B8%D1%83%D0%BC%D1%84%C2%BB.JPG
(Image on left: Duga-1 Radar Array, near Chernobyl, Ukraine. Theorized by some to be a Dead Hand System)
(Image at right: S-400 Triumf/SA-21 "Growler" surface-to-air missile system, possibly used as a Dead Hand System missile launcher)
System concept
Working principles
Upon activation and determination of the happening of a nuclear war, the system sends out a 15P011 command missile with a special 15B99 warhead which passes commands to open all silos and all command centers of the RVSN with appropriate receivers in flight. The command missile system is similar with the US Emergency Rocket Communications System. It has been theorized that several surface-to-air missile systems, such as the BUK-1 and the S-300/400 systems, are used as Dead Hand command launchers.
Components
Commanding rocket system:
Converted missile systems:
Some analysts claim that the system is connected to several surface-to-air missile batteries converted to be used by Dead Hand, ranging from the aging SA-1 all the way to the newest SA-21 missile launchers.
Surface-to-air missile theorized to be used by the Dead Hand System
Some SAMs were theorized to be converted to be used in the Dead Hand System, due to their speed, velocity, and range. This is a list of the SAMs theorized to be used by the Dead Hand System (With respective images and information from Wikipedia):
S-25 Berkut/SA-1 Guild: https://en.wikipedia.org/wiki/S-25_Berkut 220px-S-25_KYm.jpg
S-75 Dvina/SA-2 Guideline: https://en.wikipedia.org/wiki/S-75_Dvina 220px-Sa-2camo.jpg
S-200 Volga/SA-5 Gammon: https://en.wikipedia.org/wiki/S-200_(missile) 220px-ZRK_S-200V_2007_G2.jpg
2K12 Kub/SA-6 Gainful: https://en.wikipedia.org/wiki/2K12_Kub b1fe436cf0481640d930630dd81287ae.jpg
9K37 Buk (BUK-1)/SA-11 Gadfly: https://en.wikipedia.org/wiki/Buk_missile_system f2bf5d986d5f59326dcf498647d39ac6--armored-vehicles-special-forces.jpg
S-300/SA-10 missile family: https://en.wikipedia.org/wiki/S-300_missile_system 220px-Sa-10c_b.jpg
S-400 Triumf/SA-21 Growler: https://en.wikipedia.org/wiki/S-400_missile_system 300px-%D0%A1-400_%C2%AB%D0%A2%D1%80%D0%B8%D1%83%D0%BC%D1%84%C2%BB.JPG
Motivation
Operation
Current use
UVB-76 (The Buzzer)
Soviet/Russian Strategic Aerial/Electronic Defense Units
Sources
All sources courtesy of Wikipedia, Military Today, Media Commons, Wikimedia, and the New York Times archive
