SINCGARS
| Contents |
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
Background and History
The US military pioneered the use of FM voice on the battlefield in World War II with the original "three band" system, allocating 20 to 27.9 MHz to armor (100 kHz steps), 27 to 38.9 MHz to artillary (100 kHz steps) and 38 to 54.9 MHz to infantry (100 kHz steps). The famous BC-1000 or SCR-300 backpack radio fielded in WWII operated in the 40 to 48 MHz range using 200 kHz steps and FM voice. Tank radios with FM provided vast improvement over AM-based systems on the battlefield. While the SCR-300 / BC-1000 did use a VFO, it featured channels labelled on the display instead of frequency and included a fine-tuning/adjustment signal generating function for battlefield fine tuning. The SCR-300 and similar high-HF/low-VHF radios developed in WWII and the Korean War
Improvements with radio technology allowed for all three bands to be combined and moved from 20-55 MHz to 30-76 MHz and eventually 30-88 MHz, reducing channel spacing from 100 kHz to 50 kHz (Vietnam War) to 25 kHz (SINCGARS and present day). With the addition of frequency-hopping (ECCM - electronic counter-counter measures or anti-jam) and voice encryption (COMSEC) the FM radio became the standard battlefield tactical radio for ground and air communications.
