Contents[hide] |
VHF low band VHF-low
VHF high band VHF band
UHF band
800 MHz band
UHF band
Oil Spill Cleanup
These frequencies are part of the Business/Industrial Radio Pool (Business Radio Service) under Part 90 of the FCC rules. They are specifically designated for inter-system and intra-system communications relating to oil spill cleanup response and recovery operations. Use of CTCSS tones 156.7 Hz and 167.9 Hz appear to be "standardized" in some areas, but various tones are used. Digital voice modes such as Project 25 and DMR are also used, especially on the VHF/UHF frequencies. Note that most emergency response agencies - both public and private - have licenses for the itinerant business radio frequencies for use as an adjunct to the frequencies listed in on this page. The Oil Spill cleanup frequencies are often used with the 25.02 MHz to 25.32 MHz (25020 kHz to 25320 kHz) 25 MHz Petroleum Radio Service FM frequencies. 25 MHz FM activity was noted during the Deepwater Horizon clean up operation for boat-to-boat communications.
- 41.7100 MHz - Oil spill cleanup/interop (simplex or repeater input/output, often paired with 36.25 MHz)
- 150.9800 MHz - Oil spill cleanup interop (simplex or repeater input/output, often paired with 158.445 MHz)
- 154.5850 MHz - Oil spill cleanup interop (simplex or repeater input/output, often paired with 159.480 MHz)
- 454.0000 MHz - Oil spill cleanup interop (simplex or repeater output, paired with 459.0 MHz)
- 459.0000 MHz - Oil spill cleanup interop (simplex or repeater input, paired with 454.0 MHz)
