Pescadores
Pescadores, Spanish and Portuguese for "fishermen" (also perscatori in Italian), is a term used to refer to voices on the pirate bands speaking non-English languages, often Spanish or Spanish-sounding. The original assumption was that these were fishermen from Mexico, the Caribbean, and points south, on boats in the Gulf of Mexico, talking to each other or to bases on land, but this has never been proven. Normally these stations are a random annoyance to pirates and pirate DXers, but occasionally they seem to be making an effort to interfere with pirate broadcasts. Vice versa, pirate stations will sometimes attempt to interfere with the pescadores' conversations.
Freebanders on HF
- 200 meters: 1600-1800 kHz - AM mode (used in Russia and Eastern Europe)
- 150 meters: 2000-2200 kHz - AM/SSB modes (common in Russia and Eastern Europe, also marine traffic)
- 120 meters: 2300-2500 kHz - AM mode - Russia and Eastern Europe (see also: 100 meters or 3 MHz region)
- 100 meters: 2900-3500 kHz - AM mode with some SSB - very busy in Russia and Eastern Europe CIS - "Troyka"
- 70 meters: 4000-4100 kHz
- 45 meters: 6400-6700 kHz - 6.6 MHz band, EC, Echo Charlie band or 45 metros/45 meters
- 43 meters: 6765-7000 kHz
- 41 meters/39 meters: 7300 kHz + up into the 8195-8815 kHz marine band
- 22 meters: 13500-14000 kHz
- 14654.5 kHz USB - Spanish
- 10222.2 kHz USB - Spanish
- 10022.2 kHz USB - Spanish
- 10008.8 kHz USB - Spanish
- 9191.9 kHz USB - Spanish language - another "cute frequency" (easy to remember)
- 9161 kHz USB - Spanish language (also logged on 9161.3 kHz USB)
- 9055.5 kHz USB - Spanish
- 8959 kHz USB - Spanish
- various frequencies in the 7300 kHz to 8000 kHz range (8000 kHz to 8815 kHz is the 8 MHz SSB marine band)
- 6980 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6970 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6966 kHz USB - "Island Peskies" - possibly out of Jamaica mon
- 6925 kHz LSB - Portuguese
- 6919 kHz LSB - Portuguese
- 6900 kHz USB - Spanish
- 6885 kHz USB - Spanish
- 6870 kHz USB - Fishing fleets out of Gloucester, MA (English language, one of many frequencies)
- 6695.5 kHz USB and 6696.6 kHz USB - Spanish (similar to 6666.6 kHz)
- 6670 kHz USB - alternate to 6666.6 USB
- 6666.6 kHz USB - 45 metros calling frequency - home channel similar to 6900 LSB
- 6516 kHz USB - English language heard here, US based fishing trawlers (ITU HF marine channel 606)
- 6212 kHz USB - Fishermen out of New England (possibly Boston or Gloucestermen), heavy accents and very "salty language" - logged several times
- 6095 kHz USB - Fishing boats out of Gloucester, MA have been logged here - 49m broadcast band - (see also: 6212 kHz, 6953 kHz, 6959 kHz, etc)
- 5555.5 kHz USB - Spanish
- 5555 kHz LSB - English
- 5515 kHz USB - Spanish
- 5500 kHz USB - Spanish
- 5430 kHz USB - Spanish
Updated July 2019
